Results 1 to 10 of 10
Thread: Mitsubishi heavy manual
05-09-2011, 05:42 PM #1
hI aLL,
i CAME IN NEED A MITSUBISHI HEAVY INDUSTRIES MANUAL FOR FDC 1251 HKXE2 ( R22) UNITS ! THIS IS A VRF MODEL
CAN SOMEONE KINDLY SHARE IT ?
06-09-2011, 06:08 AM #2
Re: Mitsubishi heavy manual
Is it KX2 KX4 or KX6?
06-09-2011, 07:28 PM #3
David G,
It is actually KXE2 running on R22.
06-09-2011, 07:43 PM #4
Have you tried a pdf version, much lighter than the real thing !
If the World did not Suck, We would all fall off !
06-09-2011, 07:53 PM #5
Yes Chillerman 2006,
That's what I need,someone to send me KX2 manual as pdf please.
08-09-2011, 12:32 AM #6
Off topic - needed removing
12-09-2011, 06:41 AM #7
Hi, give me your email address and I will send you the manual.
12-09-2011, 09:50 PM #8
HI Dave,
Email is kerrcell@maltanet.net.
Thanks again mate,much appreciated.
12-09-2011, 10:24 PM #9
Kerrcell
For info of that unit might be best to contact www.3dair.co.uk they are agents for MHI.
In fairness if someone has it i imagine they would have offered it already.
alecMostly found in the southern part of this green and pleasant land.
13-09-2011, 08:11 AM #10
I wish I could,but here locally the agent does not want to share this old(14year) file ! So what will happen is this.If I send an email to 3dair,they will forward to local agent and end up in same position ! Here a lot of red tape.Yesterday I called the agent to order some parts and told hime that I have all the other manuals,except this 1997 one ! They try to make life more hard than it is !!!!
