Results 1 to 14 of 14
    UBAIDMD's Avatar
    UBAIDMD Guest
    Liquid line size
    I want to install 30,000 btu wall mounted mini split unit in my home.
    The recomemded refrigerant pipes sizes by the manufacturer are as followings:
    Liquid line 1/2"
    suction line 5/8"
    the refrigerant pipes which are available have diffrent liquid line 3/8"
    is this a problem for the unit.? The problem i have that i can't change the piping in home.
    Please advise me.
    muhammad ubaid
    ubaidmd@yahoo.com
    Oct 2008
    newbury
    57
    1,381
    29
    Re: Liquid line size
    what make model of unit is this
    Apr 2006
    49
    1,920
    Quote Originally Posted by r.bartlett View Post
    Evening RB
    Did wonder the same Mate
    along with what gas it was on ? whats the new gas ? 410?
    and then I looked & thought its another hit & run
    R's chillerman
    If the World did not Suck, We would all fall off !
    Oct 2007
    manchester
    44
    5,707
    If it needs a 1/2 liq line and you only have a 3/8 line then your in trouble.
    This tells me ur replacing the system,is the new system suitable for replacement technology,ie daikin rzq or mitsi power inverter?
    Best to run new lines whatever the inconvenience,flushing the lines out can have repercussions!
    Jul 2007
    Australia
    44
    1,857
    15
    Quote Originally Posted by chillerman2006 View Post
    Evening RB
    R's chillerman
    +1
    1/2" + 5/8" is a bit odd. But meh, they'll never answer any questions.
    Apr 2006
    49
    1,920
    Your right there twice Paul,
    Especially the second, so many hit & runners come here expecting a quick fix & never return to answer the thread questions, which are obviously needed to help them !
    Oh, well what do we do Gents ? Ignore the newbies or waste our time trying to help
    Its hard not to tar all with the same brush, but the repitative actions are hard to ignore !
    R's chillerman
    UBAIDMD's Avatar
    UBAIDMD Guest
    The units are from TOSHIBA (RAS-30SKP2B2), the gas is R22.
    Oct 2007
    manchester
    44
    5,707
    http://www.ingenium-company.ru/prays/toshiba%2009.xls
    says 1/4 and 5/8 pipework. check the flare nuts on the system to confirm
    Oct 2007
    manchester
    44
    5,707
    Quote Originally Posted by UBAIDMD View Post
    [XLS]
    TOSHIBA - ingenium-company.ru
    - [ Translate this page ]www.ingenium-company.ru/prays/toshiba%2009.xls
    translate the page before opening
    Oct 2007
    manchester
    44
    5,707
    Toshiba RAS-30SKP-AR2/RAS-30SA-AR2 | СтройКлимат ...
    www.ac-system.ru Кондиционеры - Cached
    Специалисты нашей компании с удовольствием ответят на все Ваши вопросы относительно сплит-системы Toshiba RAS-30SKP-AR2/RAS-30SA-AR2, ...
    it says that these are obselete also its non inverter,if it runs at 5amp then its gonna pull 90amp on start up,your lights will dim,get something newer and inverter driven
    Jul 2007
    Australia
    44
    1,857
    15
    OK, I'm willing to try this again.
    You mentioned one make and model of an A/C, what's the other one?
    Is the toshiba model you gave the one already fitted, or the one you are looking at getting installed?
    What's the other make and model you either have, or are going to fit?
    Common sizes in split systems (edit: with 5/8" suction lines), are 1/4" + 5/8", or, 3/8" + 5/8"
    Split Croatia
    6,108
    30
    R's chillerman
    Give a man some time to answer. It is passed less than 24 hours from his question and you guys already whining.
    Apr 2006
    49
    1,920
    R's chillerman
    Hi Nike
    you missed the bit that made sense mate 'hit & runners' meaning many come here 1 problem, get the info they need & never return
    not that they just don't come back to give enough info to get there 1 problem resolved
    R's chillerman
    Oct 2007
    manchester
    44
    5,707
    he could be fishing or out on the lash! be patient guru's,poor fella could have been hit by a bus! he may be hacking away at plasterboard running new pipework as we post!
