01-09-2011, 11:46 AM #1
HIYASU INVERTER HS-30LA Sensor Part required
Hi, I need to purchase the Sensor coupler PCB board that fits into my Indoor Unit HS-30LA Serial Nr. 34063
Can anyone pls tell me where to purchase this PCB part from.
The unit does not turn on from the hand remote control , so I have to turn on from the small on/off push switch inside the Indoor Unit which is a hustle as I have to use a chair every time.
03-09-2011, 08:22 AM #2
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Re: HIYASU INVERTER HS-30LA Sensor Part required
Any TV repair shop has similar and can service it for you!
03-09-2011, 08:23 AM #3
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
If you want original part check with Fujitsu-General.
http://www.fujitsu-general.de/en/dis...ion/malta.html
Also check on you digital camera if remote sends signal.Last edited by nike123; 03-09-2011 at 08:26 AM.
