    Nov 2005
    belgium
    61
    condensor screws
    Hello everybody,
    We have to make: a central with two srew compressors 134A.
    The condensors stay about 6 m lower than the compressors.
    Would be that a problem? Is it better to put the receiver as well down together with the condensors?
    And the condensor for the olicooler, we have to put this too down, would be that a problem?
    Thanks ahead,
    Greetings
    Nando
    Nov 2009
    India
    35
    32
    Re: condensor screws
    Dear Nando...
    This will not be a big problem .
    Jun 2011
    Australia
    38
    311
    Hi Nando, generally the receiver needs to be below the condenser, so the liquid can drain out of the condenser into the receiver. Normal air cooled oil cooler 6m down should be ok.
    Nov 2005
    belgium
    61
    thank you all
    greetings
    Sep 2009
    Iran
    483
    12
    main thinks in screw compressor are oil separator and oil cooler, they should be close to compressor as far as we can.
    receiver should be lower than condenser
