    White Hart's Avatar
    White Hart Guest
    Question Whirlpool K40 Ice machine
    I have a K40 ice machine & it is making ice OK but the bin is filling up with water & leaking out. The ice seems to be melting inside the bin, any ideas what would cause this.
    Mar 2008
    232
    Re: Whirlpool K40 Ice machine
    A few things to try first.
    Is the water valve shutting off the water after the harvest cycle and also check that the main bin drain is clear
    Is the drain plug water tight in the pump sump, if you reach in the machine it is on the bottom of the sump on the right hand side of the bin if you get close and at the door height you can see the drain plug.
    Is the drain tray under the evaporator installed so that the water runs back into the sump.
    If the ice is melting this also suggests that you may still be getting water from the mains via a defective water valve.
    Location, United Kingdom
    Feb 2009
    leicester
    5
    remove drain outlet and blow up drain water from hose pipe preferable your drain is blocked
    Oct 2008
    newbury
    1,444
    37
    My dad would always say "Tadley God help us" when we went through Tadley on the way to somewhere nice
