    Aug 2009
    cyprus
    22
    Mitsubishi SRC50ZD-S R410
    Hi Guys been to look at Mitsubishi SRC50ZD-S R410 inverter split unit the fan starts so does the compressor momentarily then the compressor shuts down then starts again after a minute or so, slowly at first then starts to wind up for a couple of minutes, then shuts down completely. It will rest for 5 mins then repeat the process. I have 1 blinking red light on outside board & 6 flashes on timer light on inside unit. Gas seems to be ok but compressor doesn't run for long enough to gauge running pressure. Any ideas anybody. Thanks Mack.
    manchester
    5,639
    Re: Mitsubishi SRC50ZD-S R410
    u have mail
    Aug 2009
    cyprus
    22
    Ta will read & digest. Mack.
