Hi hoping someone here may have come across this fault before. Basically the fridge/freezer has stopped working not cooling or freezing, the display panel is showing the alarm led and displaying hi temperatures which cannot be altered using the controls. The fan can be heard and the ducting tubes are warm on the back as is the compressor
the model is an AEG S75340kg98 two years old
