    brewer123's Avatar
    brewer123 Guest
    Hotpoint FZ 150 problem
    Hello, the red warning light came on and I saw that there was a huge solid block of ice behind the plastic grill at top front. I melted this off with a hair dryer. Put the fridge back on and the next morning the red light was on again. Completely emptied the freezer and turned it on again and after 24 hours the temperatute was minus 20.4. I put some tubs of water in to freeze, the temperature fell to minus 7 and after 24 hours it is minus 17. Can I trust it or can I fix it? Thanks.
    Jul 2006
    norfolk
    737
    Re: Hotpoint FZ 150 problem
    If red light been on may need a re gas
    Jul 2009
    essex
    it could possible be a defrost sensor fault in witch case it will just keep on freezing up so you would need to get a qualified fridge engineer to repair this in any case i would get it checked out before useing it again cos the cost of food now days it's worth the call out fee i hope this is usefull to you
