    May 2008
    ENGLAND
    61
    11
    Condensation probelms
    Hello engineers,
    I've been to several frost-trol multi-decks that are getting down to temp fine, the problem is the amount of condensation which is forming along the top section. Is this propbably due to the hot weather we are experiencing and if so has any one got any ideas how I can overcome this problem. Customers are moaning about the waterfalls on the meat products!
    Your help is gratefully appriciated!
    Pie Man
    Apr 2006
    49
    1,920
    Re: Condensation probelms
    Hello Pie man
    yes i would imagine the current weather is the problem
    its not the temperature though its the humidity my meter was reading 80%-95% yesterday
    the only cure is to de-humidify the shop air or you could try display curtains, they should do the trick if the counters are not accessed too often, if they are in constant use curtains will not help
    i am presuming here you have a shop display and not a van racked out in decks
