    Aug 2011
    Malaysia
    29
    8
    Refrigerant R600a
    Hi all, i am a newbie here, i got a question regarding refrigerant R600a.
    What would be the cheapest way to seal up the compressor tube after the gas completed filling. From what i got here is only welding process which previously used for refrigerant R134a.
    Oct 2007
    manchester
    44
    5,707
    Re: Refrigerant R600a
    braze a 1/4 charging stubb and leave it on r600 is basically lighter fluid and highly flammable.i wouldnt recommend a pinch off tool
    Apr 2006
    49
    1,920
    23
    Quote Originally Posted by install monkey View Post
    good advice..just be aware you will probaly have some butane left in the system so make sure you purge with nitrogen...thats presuming its not a new system your building
