Results 1 to 14 of 14
    Aug 2008
    Baltics
    786
    soldering with mapp/oxygen
    Hello
    In the face of the recent tragic accidents in Australia...
    Is it (safe and) efficient to use mapp/oxygen for soldering of pipes of say up to 3/4 inch? If I bought a rothenberger torch said to be intended for use with "all conventional fuels" plus oxygen, how successfull I would be if I used it with mapp gas? I know the new mapps are sort of crap, also, acetylen/oxy flame with its intensity, the sort of CO2 hood around it, etc features cannot be beaten by anything, but still.
    PS The in-air flame temperatures they quote for rothenberger gases are multigas 300 - 1900C, maxigas 400 - 2200C, mapp - 2400C.
    Jul 2007
    Australia
    1,845
    Re: soldering with mapp/oxygen
    This may be an expensive option for you, but worth it for the odd compressor change like I do, not worth it for someone brazing pipes in the field all day as the oxygen cylinder is $60 and only lasts 30min worth of brazing.
    http://www.tesuco.com.au/Home/08_Oxy...ng_Set.pdf.pdf
    I've used that set of oxy/MAPP for 3/4" and 5/8" no problems. Just as quick and hot as oxy-acet.
    I bought it months ago for extra storage room in my ute compared to the room that oxy - acet and regulators and hose set takes up, and for the safety aspect.
    Of course disposable oxy cylinders are expensive, and it is harder to light when it's windy (need very little MAPP pressure to get it going, it blows out at lot easier that acet when opening the oxy if you get it wrong or it's super windy, there is a reason why we use acet after all!
    but worth it to keep it for unexpected small jobs or roof top jobs, and keep the oxy acet gear in a secured area in a shed, but carefully transport it for the bigger jobs, ie don't leave oxy - acet in the van as part of the furniture everyday fixture.
    So the disposable turboset 200 cylinders won't cost you anything just to keep stocked in the van, and you can bill for their use if you need them on the spot.
    Dec 2010
    Toronto, Canada
    1,454
    I do almost everything with a turbo torch and disposable MAPP and that includes soft soldering 3" copper and brazing up to 3/4". I just picked up the dual tip that approaches the pipe at about 150deg angles which i hope will do 3/4" and 1" easily. I have a small acet tank but seldom take it anywhere.
    3,853
    Have a double barrel mapp turbo torch that has done 1 3/8" inside with no draught, and the single barrel turbo snake and rothenberger thing that will do 7/8" in similar conditions.
    Is you have something big like a drier or comp then you can use two torches to get it hot then carry on with the one.
    I tend to use them mostly for ac or liquid lines on ref, with the oxy kit for bigger pipes.
    Aug 2008
    Baltics
    786
    Thank you for sharing your experience! Is it truth or bluffs - the claims of the manufacturers that their torches are only intended to be used with their gases, and vice versa. Oxygen especially, for instance, is not it the same everywhere, essentially?
    Most importantly, can "mapp's" be used in place of "maxigase's", in general?
    3,853
    Think the connections and different on different brands of disposable fuel gas and the oxygen cylinders also.
    We have a oxy mapp set that uses refillable oxy bottles and disposable mapp ones, but not as portable as small set ups.
    Aug 2008
    Baltics
    786
    Do you think content plays no role?
    I barely I can allow myself a tesuco , or a wortington mapp/oxy torch as I dont know whether the ballons would be sent. Allmost all here to us is rothenberger, but rothenberger does not produce mapp/oxy torches - for what reason, is unclear to me. (They do maxigas/oxy, but this gas is much cheaper and lower temperature, that is why my current interest)
    3,853
    Can you get the 500g mapp tanks like this?
    http://www.londontools.co.uk/Rothenb...-Gas-453g.html
    Dave has a set that uses mapp with normal refillable oxygen bottles like a big oxy acc set up, i could try and get some pics or a vid if you are interested.
    Jon
    Jun 2010
    Yorkshire
    59
    520
    I use a hobby oxygen cylinder from Adams gas and as a fuel gas I use a 3.7 kg propane cylinder when I'm using my clocks and shank. I have used propane on its own with a 1 1/4" Bullfinch blowlamp attachment when working inside, but outside when its windy its a different story. I have braized up to 7/8" with it, and I just begrudge paying unnecessary charges to BOC for dreamt up charges. I would rather pay a one of fee and get the cylinder recharged when its empty, especially for the amount of use it gets. I used to have a BOC oxy cylinder that a friend use to fill for me when it was empty, but he lost his decanting hose.
    All fuel gasses can be dangerous when they're being used and when they're being stored, especially in the back of the van. I never understood what they tell you on the pipework and brazing course regarding an acetylene cylinder. That an acetylene cylinder should be left for at least 1/2 hour in an upright position when its been laid flat to let the liquid drain back down into the cylinder?
    I actually possess an FJTP1 C&G welding certficate back from 1982, but they still said I had to do the assessment, despite knowing more about joining metals than the assessor.
    Training may be finished but experience is never complete.
    Dec 2010
    Toronto, Canada
    1,454
    I was sure there was a thread standard that was used on the tanks like the rothenberger mappgas. I do know that the tips are all proprietary so you can't put an acet tip on a mapp handle or a Turbotorch tip on a Goss handle. with my turbotorch i buy from 6-8 different brands of tanks, depending what is available.
    manchester
    5,639
    just a health ans safety tip- mapp gas is carcinogenic!! be safe out there
    Material Safety Data Sheet
    Product name
    AIRGAS INC., on behalf of its subsidiaries
    259 North Radnor-Chester Road
    Suite 100
    Radnor, PA 19087-5283
    1-610-687-5253
    Product use
    MSDS #
    Date of
    Preparation/Revision
    In case of emergency
    Section 1. Chemical product and company identification
    MAPP GAS (Petroleum Gas, MAPD)
    Supplier
    1-866-734-3438
    Synonym :
    MAP,MAPP,Methyacetylene-Propadiene, Mixture of Methylacetylene and Propadiene
    Inhalation
    Emergency overview
    Section 2. Hazards identification
    Routes of entry
    Potential acute health effects
    Acts as a simple asphyxiant.
    Liquid or cold gas may cause frostbites.
    Ingestion is not a normal route of exposure for gases
    Eyes
    Skin
    Inhalation
    Ingestion
    Physical state
    Gas.
    See toxicological information (section 11)
    DANGER!
    FLAMMABLE GAS.
    MAY CAUSE FLASH FIRE.
    CONTAINS MATERIAL THAT CAN CAUSE TARGET ORGAN DAMAGE.
    CONTENTS UNDER PRESSURE.
    Keep away from heat, sparks and flame. Do not puncture or incinerate container.
    Contains material that can cause target organ damage. Use only with adequate
    ventilation. Keep container closed.
    Not applicable
    Medical conditions
    aggravated by overexposure
    Pre-existing disorders involving any target organs mentioned in this MSDS as being at
    risk may be aggravated by over-exposure to this product.
    Potential chronic health
    effects
    Contact with rapidly expanding gases can cause frostbite.
    Target organs :
    Contains material which causes damage to the following organs: upper respiratory tract,
    skin, eyes.
    Contains material which may cause damage to the following organs: the nervous
    system, central nervous system (CNS).
    Section 3. Composition, Information on Ingredients
    Name CAS number % Volume Exposure limits
    Build 1.1
    Page: 1/8
    Propylene 115-07-1 40 - 50
    ACGIH TLV (United States, 1/2009).
    TWA: 500 ppm 8 hour(s).
    ACGIH TLV (United States, 1/2005).
    TWA: 500 ppm 8 hour(s). Form: All forms
    Methyl Acetylene 74-99-7 27 - 33
    TWA: 1640 mg/mł 8 hour(s).
    TWA: 1000 ppm 8 hour(s).
    NIOSH REL (United States, 6/2009).
    TWA: 1650 mg/mł 10 hour(s).
    TWA: 1000 ppm 10 hour(s).
    OSHA PEL (United States, 11/2006).
    TWA: 1650 mg/mł 8 hour(s).
    OSHA PEL 1989 (United States, 3/1989).
    1,2-Propadiene (Allene) 463-49-0 13 - 15
    TLV (Philippines, 1/1978).
    TLV: 1800 mg/mł 8 hour(s).
    TLV: 1000 ppm 8 hour(s).
    Ministry of Labor (Republic of Korea,
    6/2008).
    STEL: 1250 ppm 15 minute(s).
    STEL: 2250 mg/mł 15 minute(s).
    TWA: 1800 mg/mł 8 hour(s).
    Isobutane 75-28-5 2 - 5
    TWA: 1900 mg/mł 10 hour(s).
    TWA: 800 ppm 10 hour(s).
    N-Butane 106-97-8 2 - 5
    TWA: 1900 mg/mł 8 hour(s).
    TWA: 800 ppm 8 hour(s).
    Propane 74-98-6 1 - 5
    TWA: 1800 mg/mł 10 hour(s).
    In case of contact, immediately flush eyes with plenty of water for at least 15 minutes.
    DO NOT remove contact lenses, if worn. Obtain medical attention without delay,
    preferably from an ophthalmologist.
    Immediately warm frostbite area with warm water (not to exceed 40.5 C, 105F).
    Remove contaminated clothing and shoes. Wash clothing before reuse. Clean shoes
    thoroughly before reuse. Get medical attention.
    Section 4. First aid measures
    Eye contact
    Skin contact
    No action shall be taken involving any personal risk or without suitable training.If it is suspected that fumes are still present,
    the rescuer should wear an appropriate mask or self-contained breathing apparatus.It may be dangerous to the person
    providing aid to give mouth-to-mouth resuscitation.
    Frostbite
    Try to warm up the frozen tissues and seek medical attention.
    Build 1.1
    Page: 2/8
    As this product is a gas, refer to the inhalation section.
    Move exposed person to fresh air. If not breathing, if breathing is irregular or if
    respiratory arrest occurs, provide artificial respiration or oxygen by trained personnel.
    Loosen tight clothing such as a collar, tie, belt or waistband. Get medical attention
    immediately.
    Inhalation
    Ingestion
    Lowest known value: 286.85°C (548.3°F) (Butane).
    Flammable.
    Decomposition products may include the following materials:
    carbon dioxide
    carbon monoxide
    Lowest known value: Closed cup: -108.15°C (-162.7°F). (propene)
    Lower: 2% Upper: 13%
    In case of fire, use water spray (fog), foam or dry chemical.
    Section 5. Fire-fighting measures
    Flammability of the product
    Auto-ignition temperature
    Flash point
    Flammable limits
    Products of combustion
    Fire-fighting media and
    instructions
    In case of fire, allow gas to burn if flow cannot be shut off immediately. Apply water from
    a safe distance to cool container and protect surrounding area. If involved in fire, shut
    off flow immediately if it can be done without risk.
    Contains gas under pressure. Extremely flammable. In a fire or if heated, a pressure
    increase will occur and the container may burst or explode. Gas may accumulate in low
    or confined areas or travel a considerable distance to a source of ignition and flash back,
    causing fire or explosion.
    Special protective
    equipment for fire-fighters
    Fire-fighters should wear appropriate protective equipment and self-contained breathing
    apparatus (SCBA) with a full face-piece operated in positive pressure mode.
    Immediately contact emergency personnel. Keep unnecessary personnel away. Use
    suitable protective equipment (section 8). Shut off gas supply if this can be done safely.
    Isolate area until gas has dispersed.
    Immediately contact emergency personnel. Stop leak if without risk. Note: see section 1
    for emergency contact information and section 13 for waste disposal.
    Environmental precautions
    Section 6. Accidental release measures
    Avoid dispersal of spilled material and runoff and contact with soil, waterways, drains
    and sewers.
    Personal precautions
    Methods for cleaning up
    Keep container in a cool, well-ventilated area. Keep container tightly closed and sealed
    until ready for use. Avoid all possible sources of ignition (spark or flame). Segregate
    from oxidizing materials. Cylinders should be stored upright, with valve protection cap in
    place, and firmly secured to prevent falling or being knocked over. Cylinder temperatures
    should not exceed 52 °C (125 °F).
    Use only with adequate ventilation. Use explosion-proof electrical (ventilating, lighting
    and material handling) equipment. High pressure gas. Do not puncture or incinerate
    container. Use equipment rated for cylinder pressure. Close valve after each use and
    when empty. Keep container closed. Keep away from heat, sparks and flame. To avoid
    fire, eliminate ignition sources. Protect cylinders from physical damage; do not drag, roll,
    slide, or drop. Use a suitable hand truck for cylinder movement.
    Section 7. Handling and storage
    Handling
    Storage
    Use only with adequate ventilation. Use process enclosures, local exhaust ventilation or
    other engineering controls to keep worker exposure to airborne contaminants below any
    recommended or statutory limits. The engineering controls also need to keep gas, vapor
    or dust concentrations below any lower explosive limits. Use explosion-proof ventilation
    equipment.
    Section 8. Exposure controls/personal protection
    Engineering controls
    Personal protection
    Build 1.1
    Page: 3/8
    propene
    propyne
    allene
    Ministry of Labor (Republic of Korea, 6/2008).
    Isobutane
    Butane
    propane
    Product name
    Use a properly fitted, air-purifying or air-fed respirator complying with an approved
    standard if a risk assessment indicates this is necessary. Respirator selection must be
    based on known or anticipated exposure levels, the hazards of the product and the safe
    working limits of the selected respirator.
    Safety eyewear complying with an approved standard should be used when a risk
    assessment indicates this is necessary to avoid exposure to liquid splashes, mists or
    dusts. Monogoggles.
    Personal protective equipment for the body should be selected based on the task being
    performed and the risks involved and should be approved by a specialist before handling
    this product. Neoprene and Nitrile (NBR).
    Eyes
    Skin
    Respiratory
    Personal protection in case
    of a large spill
    Self-contained breathing apparatus (SCBA) should be used to avoid inhalation of the
    product.
    Chemical-resistant, impervious gloves complying with an approved standard should be
    worn at all times when handling chemical products if a risk assessment indicates this is
    necessary.
    Hands :
    The applicable standards are (US) 29 CFR 1910.134 and (Canada) Z94.4-93
    Build 1.1
    Page: 4/8
    Consult local authorities for acceptable exposure limits.
    -102.8°C (-153°F) This is based on data for the following ingredient: propyne. Weighted
    average: -152.56°C (-242.6°F)
    Highest known value: 2 (Air = 1) (Isobutane). Weighted average: 1.47 (Air = 1)
    Lowest known value: 91.9°C (197.4°F) (propene).
    42 g/mol
    Melting/freezing point
    Section 9. Physical and chemical properties
    Molecular weight
    Critical temperature
    Vapor density
    Gas Density (lb/ft
    3) :
    Weighted average: 0.11
    The product is stable.
    Conditions to avoid: Stable as mixed; however, contains unstable materials
    (methylacetylene and propadiene). Weathering off (evaporation of light components)
    may allow concentration of the methylacetylene and propadiene to reach concentrations
    which would make mixture unstable on heating. Avoid heating of mixture or venting of
    lights that could cause lighter materials to weather off(evaporate).
    Extremely reactive or incompatible with oxidizing agents.
    Reactive with metals.
    |Additionally, avoid contact with acetylide-forming metals (copper,silver and mercury).
    Copper alloys (such as brass) containing sixty six percent (66%) or more of copper
    should not be exposed to MAPD.
    May Occur.
    Conditions to Avoid: Elevated tempertures and pressures. Polymerization catalysts,
    such as metal alkyls, can cause uncontrolled polymerization. Contamination with oxygen
    can cause propadiene to form hazardous peroxides.
    INHIBITORS/STABILIZERS
    An ihibitor is added to the MAPD mixture to prevent potential unstable peroxide
    formation. Butanes (iso and/or normal) are also added to the MAPD mixture to prevent
    potential concentration of the methylacetylene and propadiene from reaching
    concentration levels that would render the mixture unstable in case of weathering off
    (evaporation of light components).
    Under normal conditions of storage and use, hazardous decomposition products should
    not be produced.
    Section 10. Stability and reactivity
    Incompatibility with various
    substances
    Hazardous decomposition
    products
    Hazardous polymerization
    Section 11. Toxicological information
    Specific effects
    Carcinogenic effects
    See ACGIH Carcinogen classification.
    Mutagenic effects
    No known significant effects or critical hazards.
    CARCINOGENIC EFFECTS
    : Classified A4 (Not classifiable for humans or animals.) by
    ACGIH [Petroleum Gas, Liquefied (MAPD, MAPP GAS)].
    Chronic effects on humans :
    Toxicity data
    Isobutane LC50 Inhalation
    Vapor
    Rat 658000 mg/m3 4 hours
    LC50 Inhalation
    Gas.
    Rat 57 pph 15 minutes
    Butane LC50 Inhalation
    Vapor
    Rat 658 g/m3 4 hours
    Product/ingredient name Result Species Dose Exposure
    Build 1.1
    Page: 5/8
    Reproduction toxicity
    Products of degradation: carbon oxides (CO, CO
    2) and water.
    Section 12. Ecological information
    Products of degradation :
    Environmental fate :
    Not available.
    Environmental hazards :
    Toxicity to the environment :
    Not available.
    Aquatic ecotoxicity
    Not available.
    Section 13. Disposal considerations
    Product removed from the cylinder must be disposed of in accordance with appropriate Federal, State, local
    regulation.Return cylinders with residual product to Airgas, Inc.Do not dispose of locally.
    Section 14. Transport information
    DOT Classification
    2.1 -
    TDG Classification
    2.1
    Methyl Acetylene and
    Propadiene mixtures,
    stabilized
    UN1060 Methyl Acetylene and
    stabilized
    Regulatory
    information
    UN number Proper shipping
    name
    Class Packing group Label Additional
    information
    UN1060
    Explosive
    Limit and
    Limited
    Quantity
    Index
    0.125
    ERAP Index
    3000
    Passenger
    Carrying
    Road or Rail
    Index
    Forbidden
    Mexico
    Classification
    stabilized
    2.1 -
    Not applicable (gas).
    “Refer to CFR 49 (or authority having jurisdiction) to determine the information required for shipment of the
    product.”
    Section 15. Regulatory information
    U.S. Federal regulations
    United States inventory (TSCA 8b):
    All components are listed or exempted.
    SARA 302/304/311/312 extremely hazardous substances
    : No products were found.
    SARA 302/304 emergency planning and notification
    SARA 302/304/311/312 hazardous chemicals
    : propene; Isobutane; Butane; allene;
    propyne; propane
    SARA 311/312 MSDS distribution - chemical inventory - hazard identification
    propene: Fire hazard, Sudden release of pressure; Isobutane: Fire hazard, Sudden
    release of pressure; Butane: Fire hazard, Sudden release of pressure; allene: Fire
    hazard, Sudden release of pressure; propyne: Fire hazard, reactive; propane: Fire
    United States
    Build 1.1
    Page: 6/8
    Connecticut Carcinogen Reporting:
    None of the components are listed.
    Connecticut Hazardous Material Survey:
    Florida substances:
    Illinois Chemical Safety Act:
    Illinois Toxic Substances Disclosure to Employee Act:
    listed.
    Louisiana Reporting:
    Louisiana Spill:
    Massachusetts Spill:
    Massachusetts Substances:
    The following components are listed: PROPYLENE
    (PROPENE); PROPYNE; ISOBUTANE; BUTANE; PROPANE
    Michigan Critical Material:
    Minnesota Hazardous Substances:
    New Jersey Hazardous Substances:
    PROPYLENE; 1-PROPENE; METHYL ACETYLENE; 1-PROPYNE; PROPADIENE; 1,2-
    PROPADIENE; Isobutane; PROPANE, 2-METHYL-; BUTANE; PROPANE
    New Jersey Spill:
    New Jersey Toxic Catastrophe Prevention Act:
    New York Acutely Hazardous Substances:
    New York Toxic Chemical Release Reporting:
    Pennsylvania RTK Hazardous Substances:
    The following components are listed: 1-
    PROPENE; 1-PROPYNE; PROPANE, 2-METHYL-; BUTANE; PROPANE
    Rhode Island Hazardous Substances:
    Clean Water Act (CWA) 307
    Clean Water Act (CWA) 311
    Clean Air Act (CAA) 112 accidental release prevention
    allene; propyne; propane
    Clean Air Act (CAA) 112 regulated flammable substances
    Butane; allene; propyne; propane
    Clean Air Act (CAA) 112 regulated toxic substances
    State regulations
    CEPA DSL: Propylene; Isobutane; Butane; propadiene; Methyl Acetylene; Propane
    CPR Compliance: This product has been classified with a hazard criteria of the CPR,
    and the MSDS contains all the information required for CPR.
    WHMIS (Canada)
    Class B1: Flammable Gases
    Class A: Compressed Gas
    SARA 313
    Form R - Reporting
    requirements
    Supplier notification
    Canada
    Product name CAS number Concentration
    SARA 313 notifications must not be detached from the MSDS and any copying and redistribution of the MSDS shall
    include copying and redistribution of the notice attached to copies of the MSDS subsequently redistributed.
    Section 16. Other information
    FLAMMABLE GAS.
    Label requirements :
    United States
    Canada
    Build 1.1
    Page: 7/8
    Notice to reader
    To the best of our knowledge, the information contained herein is accurate. However, neither the above-named
    supplier, nor any of its subsidiaries, assumes any liability whatsoever for the accuracy or completeness of the
    information contained herein.
    Final determination of suitability of any material is the sole responsibility of the user. All materials may present
    unknown hazards and should be used with caution. Although certain hazards are described herein, we cannot
    guarantee that these are the only hazards that exist.
    1
    4
    1
    National Fire Protection
    Association (U.S.A.)
    Health
    Special
    Instability
    Flammability
    Hazardous Material
    Information System (U.S.A.)
    1
    4
    1
    Health
    Flammability
    Physical hazards
    Build 1.1
    Page: 8/8
    Aug 2008
    Baltics
    786
    Jon
    If that rothenberger mapp has 7/16 inch connection, then, yes, they are obtainable to us. What is Dave? (such variant would be very nice for me - ideally with some 2l refillable oxygen bottle)
    3,853
    Quote Originally Posted by Yuri B. View Post
    Dave is my business partner
    The set is sold by a local wholesaler but i can't find a picture or link to it.
    Will take some pics next time i'm working with Dave!
    IM, thats the old methylaccypropy mapp gas, new MappPro is in fact propylene,
    http://www.nationalref.com/PDF%27s/M...PP_pro_Gas.pdf
    Jon
    Aug 2008
    Baltics
    786
    Monkey spanners, if you get the link, please, post it here (although I doubt they would send the kit to the other end of EU).
    Install, what has always been striking to me : why many profi welders are smokers? I hope once a week or even a month using the mapp could not turn to be harmfull.
