    Sep 2010
    denmark
    26
    8
    Semi Hermetic Compressor Failures
    are there any statistics available to understand the main causes of compressor failures? is it more electrical failures or mechanical failures?
    I appreciate your help.
    Sep 2003
    ISRAEL
    66
    4,119
    38
    Re: Semi Hermetic Compressor Failures
    I don't know about statistics but in most cases its down to electrical failure.
    Nov 2009
    India
    34
    32
    The compressor failuer depends upon its application
    every compressor has its own limit of application,depend upon the working
    they will sustain.
    What i found is most damges are from electrical part in semi hermetic compressors
    Mar 2006
    Merate (LC) - Italy
    2,553
    liquid slugging is a good second, especially for refrigeration.
    Sep 2010
    denmark
    26
    8
    Thanks for your replies. Can you please classify the electrical failures you are referring to? single phasing / low or high voltage etc?
    Apr 2011
    India
    30
    94
    7
    Electrical failures - Electric Motor failure, mostly due to " winding failure " or " bearing failure " .
