    kenb's Avatar
    kenb Guest
    Angry Hi - Daikin inverter problem
    Non functional and flashing L5 which I understand is a compressor earth or short problem. Anything that a householder can check for before calling a technician?
    Oct 2008
    newbury
    1,444
    Re: Hi - Daikin inverter problem
    Your bank balance for a starters!
    manchester
    5,639
    buy an inverter checker and that will prove ur inverter is ok and ur comp is siezing then u need to buy an inverter board anyway for the 12mth warranty
