Page 2 of 2 FirstFirst 12
Results 51 to 66 of 66
Thread: daikin vrv's
  1. #51
    5,667
    Re: daikin vrv's
    Stupid me - I've just caught up with the postings in the Moderators Area
  2. #52
    Oct 2003
    5,630
    Re: daikin vrv's
    Me to, but that doesn't make me to change my post nor edit it.
    Now it comes...........again.......all the abbreviations with 4 letters, NRIJ,.....describing the whole being of a person in just 4 letters.
    A M A Z I N G
    Could refrigeration be that simple......
  3. #53
    MRcoolingMAJIC's Avatar
    MRcoolingMAJIC Guest
    Re: daikin vrv's
    Hi, Peter_1.
    What is the difference between changing a post and editing a post?
    Thanx for the attention.
  4. #54
    Apr 2001
    2,099
    27
    Re: daikin vrv's
    Is this place becoming all
    schitzophrenic?????????
    ( I have never been able to spell that)
    Any opinions, statements and facts expressed in this message do not constitute legal advice in any shape or form and is given for a general outlook in nature. You are advised to seek appropriate and specific professional assistance from a regulated and authorised advisor for definitive advice.
  5. #55
    5,667
    Re: daikin vrv's
    Hi Raymond
    Just re-visiting this old thread.
    Did you manage to sort out the problem with your G series unit?
    Any chance of an update - don't forget - we do site visits for reasonable reward
  6. #56
    Jan 2003
    East Anglia
    1,160
    Re: daikin vrv's
    Quote Originally Posted by frank
    Hi Raymond
    Hi Frank,
    First things first, ever thought of moving to Cambridge. I know a company looking for a good Daikin engineer, Unfortunatly they got me instead
    Strangly got called back to the site today as the customer wants it SORTED OH REALLY !!!
    Now, can't be arsed to go through previous posts to see what i've put plus my dial up is getting slower and slower so would take me all night, what i think however
    VRV has a cooling rating of 162.5
    Indoor units add up to 212 so in theory should have never worked. Customer response "It used to work !"
    Now the reception area of the building used to be seperate rooms but now its all gone open plan so i think more duty is being put on the unit. Also the unit is getting older (Arnt we all) and therefore probably having to work harder.
    Now, i would like to reclaim, vac out overnight and regas. My problem then is, If i regas to the original VRV spec, surely this is enough gas to cope with a 162.5 capacity and not 212, therefore how much extra gas should i put in.
    The problem its on a fully comp contract. Therefore my company doesn't want me to spend vast amounts on gas and it not clear the fault, the customer on the other hand doesn't care how often they call us as i doesn't cost them.
    Oh the joys of the job
    Ray
  7. #57
    5,667
    Re: daikin vrv's
    Raymond
    What's the PAY like
    My daughter lives in St Ives so I'm a regular visitor to the area
    Yes but did it work as it should?
    You just can't overcharge a system that is out of manufacturers spec and expect the extra refrigerant to make it work It is out of design - full stop (based on your previous information). What you need to do now is come up with a solution to make the system work - not to just give the customer what he wants to hear.
    Why not suggest to the customer that you ought to bring in a Daikin specialist to confirm the system is not installed to manufacturers specs and that to solve the problem will cost him some money? after all it's not your fault. Plus I may get to spend the night visiting the daughter
    I'll only charge the same as Space Air or Daikin UK
  8. #58
    Jan 2003
    East Anglia
    1,160
    Re: daikin vrv's
    Raymond
    What's the PAY like
    Hi Frank,
    Better speak to cooling-gurus about that one
    Looking at the site list i have, the main reception open plan area just off it have 2x40's 1x32 & 2x25. This if my math is righ is 162. There are two other units on this system on offices both 25's. I suppose the obvious answer would be to take these two off the circuit and put on their own condensing units.
    Sounds simple but i expect it to be a pig of a job.
    Anyway i have done my bit, i can only report what i find. Its up to those far higher up the ladder than me to come up with a solution
    Raymond
  9. #59
    Aug 2004
    744
    Re: daikin vrv's
    Quote Originally Posted by rdocwra
    I don't know too much about these things but...
    Can you not size a vrv/vrf at 130% ? because not all indoor units will be switched on or running at 100% all of the time.
    ie 162.5 +30% = 211 therfore,just inside the design limit.
    cheers
    eggs
  10. #60
    5,667
    Re: daikin vrv's
    Unfortunately you can't put VRV indoor units on normal condensing units. Each VRV indoor unit has a built in EEV for refrigerant control and Skyair condensing units have the EEV on the outdoor.
    Although you could use the 2 x 25's on a super multi but this would be more expensive than just putting in 2 new split systems.
  11. #61
    rbartlett's Avatar
    rbartlett Guest
    Re: daikin vrv's
    this is a R22 system so you're effed anyway...
    cheers
    richard
  12. #62
    5,667
    Re: daikin vrv's
    Quote Originally Posted by eggs
    cheers
    eggs
    Not quite Eggs.
    In one respect the system can operate at 135% capacity which will mean that the indoor performance is reduced but the maximum index of the outdoor unit should not be exceeded. The high end index number relates to the 135% capacity so if you go over this then the indoor performance reduces even more as is evident by Raymond's system.
    When designing a system you should calculate the indoor index numbers then select the outdoor to match - if some of your indoor units only run very little and you don't mind the temporary drop in performance then you can select the outdoor at a high index.
    It's easier to understand with the selection charts in front of you
  13. #63
    Jan 2003
    East Anglia
    1,160
    Re: daikin vrv's
    Hi Eggs,
    I theory it could work like that, unfortunatly since they have gone all open plan the units are having to work hard all the time, especially as the receptionist thinks she's in spain and runs it at 25 all day long. I think the system would have coped before as units will have shut down in their smaller area's but no chance of that now
    Fatboy
  14. #64
    5,667
    Re: daikin vrv's
    Raymond
    I found this troubleshooting guide for checking refrigerant charge
    Attached Files Attached Files
  15. #65
    Re: daikin vrv's
    Nice one, thanks Frank
  16. #66
    Dec 2005
    Johor
    151
    Re: daikin vrv's
    RD
    I was going to mail message you some details regarding the fault encounter but system was down. Here are the attachment. Mine are all hardcopies, hard to post the manuals down here. If you're here maybe I can hand it over to you.
    Hope this things helps.
  1. Daikin VRV Checker
    By bobjob in forum Air Conditioning
    Last Post: 04-01-2009, 08:10 PM
  2. New to RE and needing Daikin Help
    By Owen in forum Air Conditioning
    Last Post: 25-09-2008, 06:55 PM
  3. Daikin Analyzer
    By marc5180 in forum Fundamentals
    Last Post: 02-08-2008, 07:15 PM
  4. Daikin Controllers
    By airefresco in forum Air Conditioning
    Last Post: 15-05-2008, 08:08 AM
  5. !!big Daikin Problem!! Codes,u4,pj, And E0
    By airconengineer in forum Air Conditioning
    Last Post: 31-05-2007, 09:04 PM
