Results 1 to 10 of 10
Thread: battery powered fridge unit
08-07-2011, 11:10 PM #1
Re: battery powered fridge unit
Have a look at the Danfoss BD 12/24vdc compressors.
If you want to spend money then try a marine unit, same make just more bucks.Brian - Newton Abbot, Devon, UK
09-07-2011, 12:47 AM #2
good call its if the capacity can be obtained the problem is the van had a engine driven unit and the bolts sheared in the engine block the muppets who tried to extract the remains of the mounting bolts snapped a extraction tool in the block and it cannot be removed thus making the mounting of a new bracket mount kit impossible without a new engine being installed!
09-07-2011, 07:36 AM #3
There is no screw that You can not get out, find normal mechanics who wil extract bolts and renew the threads.
