    under_dog's Avatar
    under_dog Guest
    Coca cola double door display fridge.
    Hi all. I have recently took over a small busniess. It has two coca cola double door display fridges. I have the thermo on both set at 0 yet the soft drinks get uncomfortably cold. Is there anyway to switch the condenser off but leave the display lights on?
    The units also account for half of my electricity consumption.
    Jan 2006
    Adelaide , Australia
    192
    Re: Coca cola double door display fridge.
    The Thermo should be set at 2 Deg C , Zero is almost freezing , the light should stay on even when the thermo cuts the unit off or do the display lights go out when the unit cuts out or just when you turn off the mains ?
    60% of the time it works everytime.
    May 2011
    Essex
    54
    14
    I guess you have TRUE GDM 33's
    Unfortunately they are juice busters, so turn the stat up as a compromise, the drinks will be warmer and the bills less!
    Jan 2003
    East Anglia
    1,160
    Make sure the condenser is clean. True's are controller by a stat which is INSIDE the evap and not on air temp. It has been known if the condenser it dirty, the evap doesnt get cold enough to switch off the condensing unit and stock to get too cold. Sounds weird i know, evap not getting cold enough but fridge too cold but trust me ive seen it a few times now
    11,025
    I may be wrong but aren't Coca Cola responsible for their own units? Free advertising for a cold shelf....
    If so, call them in.
    Jun 2010
    Yorkshire
    59
    520
    Yes indeed they are, all coca cola units always belong to coca cola. The deal is that you stock 30% of their products and then you can stock your own choice. They don't charge for repairs or service and when you order a unit it may be new or reconned.
    The trueline units are reknown for having dirty condensor coils, but there should be a seperate switch for the lights inside the unit.
    Training may be finished but experience is never complete.
