Thread: fujitsu starters
04-07-2011, 12:43 AM #1
fujitsu starters
hi every one new on here i work on refrigeration comercail not a full bottle on ac i have a problem with a starter on a split whats the best way to test these things or can they be ripped out and run the comp through a normal contacter
04-07-2011, 08:01 AM #2
Re: fujitsu starters
what is the model of the split system. is the motor starter black with 6 terminals?
c_t
04-07-2011, 01:41 PM #3
Try to use points in your sentence because this is very difficult to read.
No you can't, you need the special starting relays/devicesIt's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
08-07-2011, 10:46 AM #4
Fujitsu ones are probably the best out there and pretty reliable. It's required by legislation to have them and for 7kW+ system you really need one, if it's an old 6kW system you could get away with not having it if it's your own a/c not a customers a/c.
There's been a recent thread on this where there's more info.
