27-06-2011, 07:47 PM #1
Samsung E464 Code=IPM Over Current (O.C) on AQV24BEX ***NEED HELP****
I bought this Samsung and I was easy to install and ran great for about 30 days then it stopped pushing cold air with a code of E464=IPM Over Current (O.C). I tried to reset the codes with no luck so I replaced the mother board (PCM) and it's still pulling the same code. My neighbor thinks the power coming from the house is a little high 238V and this my be causing the code.
Any thoughts?
27-06-2011, 10:57 PM #2
Re: Samsung E464 Code=IPM Over Current (O.C) on AQV24BEX ***NEED HELP****
According to the faults codes that I found it could be due to obstructions at both units or refrigerant charge.
http://www.logicool-ac.com/samsung_t...%20Display.pdfBrian - Newton Abbot, Devon, UK
27-06-2011, 11:03 PM #3
measure the current into the condenser to see if this is as per name plate,then check the gas charge.
