Results 1 to 12 of 12
Thread: 10kw wall mount
    Oct 2008
    newbury
    1,444
    37
    10kw wall mount
    Apart from Daikin who else sells a 10kw wall mount single split (not a twin etc)
    Oct 2007
    manchester
    5,639
    45
    Re: 10kw wall mount
    fujitsu,mitsubishi,hitatchi-the daikin 10kw is exactly the same facia design
    Oct 2008
    newbury
    1,444
    37
    Re: 10kw wall mount
    Quote Originally Posted by install monkey View Post
    I accept Mitsi and I can't find anything above 8kw for Hitachi?
    but I know Fujitsu certainly don't go above 8kw..
    Oct 2007
    manchester
    5,639
    45
    Re: 10kw wall mount
    hitatchi utopia es wall mtd rpk 4.0fsn2m 10kw cooling 11.2 heating
    fujitsu ASYA30LC outdoor AOYR30LC apologies only 8kw cooling 9 kw heating
    sanyo dont,toshiba dont,samsung and marstair dont
    Oct 2008
    newbury
    1,444
    37
    Re: 10kw wall mount
    Thanks ...
    The single fan condenser helps the install. Are Hitachi any good these days?
    Oct 2007
    manchester
    5,639
    45
    Re: 10kw wall mount
    they used to be reliable except for when the compressor feet corrode and as the comp has flared fittings' it used to twist and kink the pipework
    mitsi -if u go power inverter then u get a single fan cond and a free sheet of polythene to cover the comms pcb to catch the rain and direct it to the pcb!
    87
    Re: 10kw wall mount
    Sanyo has a 10 kw wall mounted unit as well; new unit SPW-K366H.
    Grts,
    Pol
    Nov 2006
    Cheshire, UK
    56
    360
    Re: 10kw wall mount
    Can recomend the Mitsi Elec 10kW Power Inverter unit, fitted 5 or so of these now.
    Indoor unit is no wider than a standard 7kW unit which helps massively on some jobs.
    Outdoor is twin fan though not single.
    He who dies with the most Toys, WINS!
    Oct 2007
    manchester
    5,639
    45
    Re: 10kw wall mount
    apologies-power inverter 1 and 3 phase twin fan
    pka rp100 kal single fan standard inverter
    Oct 2008
    newbury
    1,444
    37
    Re: 10kw wall mount
    Power inverter? You must think we're made of money down here!
    Oct 2007
    manchester
    5,639
    45
    Re: 10kw wall mount
    is that why you specified wall mounts! for a cheaper option how about cutting a hole in the mud hut and calling it a window! haha
    Dec 2005
    Cheshire
    264
    21
    Re: 10kw wall mount
    The new Sanyo 10kw wall (classic inverter) has a single fan outdoor.
