Thread: frigoblock fk13
    Sep 2008
    71
    5
    frigoblock fk13
    Hi,my frigoblock has decided to stop cooling and temp inside stays about 10degrees
    tried altering temp control up and down no effect only serviced 2 weeks ago gas fine belts all ok all 3 fans running ok cant get any help until monday problem is about 2 tons meat in at the moment,anything else a novice could check.
    thanks philb.
    Dec 2010
    devon
    837
    Re: frigoblock fk13
    blown coil/ eutentics /alt driven?
    Jun 2011
    United States
    9
    Re: frigoblock fk13
    I think you should consider replacing it as it would give better results.
    _______________________
    Seo Marketing
    Marketing Seo
    Sep 2008
    71
    5
    Re: frigoblock fk13
    Thanks to charlie patt & mmack1993. have since replaced expansion valve and improved performance for 2 days then 2 out of 3 fuses blew back at isolator switch, replaced them and up and running again briefly until compressor almost seized and seems now need to replace compressor and are not cheap,any leads for a replacement compressor its a frigoblock fx3-az20 runs on r410.
    thanks,philb
