Results 1 to 19 of 19
Thread: Flogging a dead horse.
12-10-2005, 09:57 AM #1
Re: Flogging a dead horse.
Originally Posted by Temprite
Im thinking on this one
Its not a restriction I dont think
If it was a restriction you would be in vacuum
I know, youre thinking , maybe its a partial vacuum
Your back pressure 15psi is correct
This is my advice
Switch off your evaporator fans
Add refrigerant till the whole evaporator coil is iced
At this point stop adding refrigerant
Make sure your condensor coil is clean
See how it goesAny opinions, statements and facts expressed in this message do not constitute legal advice in any shape or form and is given for a general outlook in nature. You are advised to seek appropriate and specific professional assistance from a regulated and authorised advisor for definitive advice.
12-10-2005, 08:30 PM #2
No one yet has mentioned checking the compressor running current - it's a must when charging a system.
Too little refrigerant and low amps, too much refrigerant and high amps. All part of the overall picture.
12-10-2005, 09:38 PM #3
Yes Frank, But if there is a partial blocked cap tube, then your amps will not show the truth.
Chemi
compressor horse power
By ewart in forum Industrial CompressorsReplies: 9Last Post: 27-07-2009, 05:39 PM -
Horse power rating
By Argus in forum Air ConditioningReplies: 0Last Post: 03-02-2005, 10:52 AM -
motor horse power
By mtoto in forum FundamentalsReplies: 4Last Post: 05-06-2002, 03:32 AM
