Thread: Dixell
    MIODRAG's Avatar
    MIODRAG Guest
    Dixell
    Dear all
    we replaced controller and placed dixell ic208cx. After all parametars entered all we got is blinking sign of compressor 1. We could not find user manual for it, only quick reference guide that we already have. Any information? Condensers are independently controlled by pressure switch. Thanks in advance
    Mar 2006
    Merate (LC) - Italy
    2,553
    Re: Dixell
    Blinking means that it is ready to start, but waiting for delay time.
    Sep 2003
    ISRAEL
    66
    4,120
    38
    Re: Dixell
    You should look in the parameter list under CO.
    There are a few delays there, so read carefully and see if you need to change anything.
    69
    10,509
    Re: Dixell
    Jun 2011
    United States
    29
    9
    Re: Dixell
    _______________________
    Seo Marketing
    Marketing Seo
    Jul 2011
    69
    Re: Dixell
    Hope you have sorted it out by now but in case you haven't, the compressor delay timer is one cause for a blinking compressor icon but another could be that one of the digital inputs could be holding the compressor off. I don't know if you have wired any of these in but when the controller comes out of the box, all digital input polarity parameters are set as CL (active on a closed circuit). This ensures the controller operates as normal with nothing connected. If a pressure switch is connected, these normally require the polarity of the digital input to be changed to OP (active with open circuit) - Good luck.
