    Jun 2010
    NZ
    69L drop in...??????
    Hello, I have an existing freezer room running on R69L. I am still a bit short on charge and have no 69L left. Is there any other refrigerant that I can drop in on top it...????
    Thanks Scooter.
    Dec 2010
    devon
    837
    Re: 69L drop in...??????
    we use 422 or oil change and 404a it
    Short answer is NO. You shouldn't mix refrigerants without full knowledge of what you are mixing.
    You could replace it though.
    Feb 2009
    telford
    2,090
    33
    69l is a drop in for r502 i think,so recover it all send it for recycling then oil change ,flush triple vac recharge with 404a,and i would change oil again after one week of running of coarse change the filter drier,any suction core filters drain oil sep etc,bottom line is a big job best of luck,first thing to check is are you certain its short of refrigerant?.
