Results 1 to 2 of 2
    Jun 2007
    Leicester
    44
    R134A Running Pressures
    Apologies if this is in the wrong thread!
    We have been asked to look at a walk in freezer operating on on R134A i have never been to look at a freezer running on R134A what sort of running pressures should i be looking for to get the freezer down to -18oC? Currently the freezer is only achieving around -8oC
    Am i right in thinking the suction should be around 1psig?
    Thanks in advance for any help
    Jan 2008
    Somerset
    75
    11
    Re: R134A Running Pressures
    Hi Borodave,
    Forget about pressures and use temperature. You should be evaporating at about -25'C for a freezer. So look for -25'c on your blue gauge on the 134a scale.
    To keep it simple, use these rules of thumb:
    Freezer = SST of -25'c
    Coolroom = SST of -5'c
    AC = SST of +5'c
    Using these 3 temperatures you will be able to work with any refrigerant.
