Results 1 to 10 of 10
Thread: charging weight
    Feb 2005
    sliema
    52
    138
    charging weight
    Guys,
    I have a 4 door fridge comersa.No model label.Compressor was replaced to an Electrolux GP12TB 2 years ago. running on R134a. I need to change again compressor.Any on know how much grams to charge of R134a ? Compressor is 12ccs ( 510w approx)
    Jun 2009
    Lusk , Dublin
    1,115
    Re: charging weight
    I presume you will recover the existing charge ?
    So recharge with the amount removed prior to the work been undertaken.
    Stu
    Tool's ? check ! Condom's ? check !
    Jun 2009
    North East England
    41
    712
    Re: charging weight
    Quote Originally Posted by stufus View Post
    Stu
    Lol like that's gonna happen
    Jun 2009
    Lusk , Dublin
    1,115
    Re: charging weight
    Quote Originally Posted by james10 View Post
    Probably not!
    Stu
    Apr 2010
    295
    15
    Re: charging weight
    like the comments reclaim lol how about you apply the 15 deg rule of thumb see if it works
    Jan 2006
    Adelaide , Australia
    192
    Re: charging weight
    Does the 4 door cabinet has a evaporator fan ? If so disconnect the power to the fan charge till coil fully flooded , reconnect fan . Once you restart the fan it will have some work to do so just pack up and go to the pub or home !!
    60% of the time it works everytime.
    Oct 2007
    manchester
    5,639
    45
    Re: charging weight
    squirt and blow method-overcharge,wait for suction to flood back,blow a bit,wait,blow a bit,wait. if it reaches temp,great if not add a bit,bit more repeat if nessesary!
    Jul 2010
    NTH.QLD Australia
    1,730
    32
    Re: charging weight
    Quote Originally Posted by kerrcell View Post
    Guys,
    EH? 12cc compressor on a 4 door? Are you working on a stand alone 4 door bottle cooler?
    Feb 2005
    sliema
    52
    138
    Re: charging weight
    Hi guys,
    A late reply though ! Yesterday during the night manged to change compressor.Have reclaimed but charged with fresh gas.I worked by superheat but the idea of temporary disconnecting the evp fan,I liked and will try next time .What is the 15 degrees rule,I presume it is tyhe superheat you are referring to .
    Apr 2010
    295
    15
    Re: charging weight
    15 degree rule of thumb take air on condenser and add 15 degrees to it and get your comparitor out find that temp on the gas you are using and thats what yr discharge should be when fully charged dead easy one to remember that and easy
