Results 1 to 8 of 8
Thread: Name
    haiti
    26
    Name
    if you have a pool of water with the copper tube evaporator around it (inside). the system cool the water .how do you call it?
    thanks
    Mar 2011
    Singapore
    212
    10
    Re: Name
    Heating for swiming pool I beleived, so you should call heat pump.
    haiti
    26
    Re: Name
    this is the water(brine) on the pool we cool
    Auckland
    68
    3,362
    31
    Re: Name
    chlorine in water will eat holes in copper pipe
    Mar 2009
    ireland
    87
    10
    Re: Name
    if its building some ice on the pipe we would call it an ice bank cooler
    used a lot in beer cooling
    or its a water chiller
    or call it what you want if its doing the job correctly a bucket if its not!!!
    Oct 2006
    1,848
    15
    Re: Name
    Quote Originally Posted by payoute View Post
    thanks
    So you want to cool water with a copper tube inside that water?
    If the tube is inside and ice forms around it, it is called an ice bank.
    If the tube is outside the water then it is a water chiller.
    The ice bank method is used to store up cooling, so it can be released over time,
    in a milk tank or beer cooler (as has been explained) these tend to be used when
    large amounts of cooling is required in a short time.
    The water chiller type can take many forms but tend to be continuous cooling.
    Hope that helps
    All the best
    taz
    Mar 2011
    Singapore
    212
    10
    Re: Name
    Sorry my mistake for "haiti".
    haiti
    26
    Re: Name
    Thanks every one for yours answers
    I think this is an Ice bank since there is store on the pool, not circulate and the tube is inside the water
    Now if the pool water (water and salt) is 200 gallons and I want to cool it from 38 C (100.4 F) to – 15 C (5 F) in 30 minutes how to make the calculations
    M*Cp*dt =(200*3.78 *53 *3.9)/1800= 87 kw
