Results 1 to 2 of 2
    Sep 2008
    Letsby Avenue
    359
    Whirlpool S200BTSB21
    Defrost problem on side by side, Element is OK ,does the defrost terminate by time or temperature.No defrost timer so it is controlled by pcb but unsure as to which way it ends.
    “Life is like riding a bicycle. To keep your balance you must keep moving” Einstein
    Jul 2010
    NTH.QLD Australia
    1,730
    32
    Re: Whirlpool S200BTSB21
    Spimps, pcb will allow a set time for defrost but temperature sensor is the primary trigger, or should i say, the defrost sensor/ probe.
