Threaded View
04-06-2011, 12:50 PM #1
TEV with or without equalizing line
Let's discuss the following: can you use a TEV with internal equalizing line on an evaporator with a distributor in a conventional storage cold room with a relative stable load?
If so why?
If you can't, why not?
Can a TEV with internal eq. work as well as a type with external eq. on a coil with distributor?
Is the choice for an TEV with or without eq. line determined by the construction of the evaporator or more by the application?It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
