Results 1 to 2 of 2
03-06-2011, 02:00 AM #1
electrolux RM4368 NOT WORKING ON GAS
Hi ive got a electrolux rm 4368 not working on gas it works fine on 240 volts and 12 volts dc but not gas cleaned flu at rear got right colour flame but not enough heat to condense i think it could be gas valve but not 100% .its a pain to remove from motor home ,any help would be gratefully recieved.thanks
03-06-2011, 01:27 PM #2
Re: electrolux RM4368 NOT WORKING ON GAS
You must be gas safe qualified/registered to carry out repairs.
If you have cleaned flue jet MUST be changed too,worked for Electrolux for many years and never cleaned a flue without a burner and jet change depending on which model plus if the flue is dirty it's a sure sign that that jet and burner aren't efficient.
Looks and colour of a flame don't indicate accurately the btu input.
Bite the bullet it's worth it in the long term.
Pain,removing fridges from Carlight trailers in February laid underneath cutting off rusty bolts with wet and freezing hands,now that was a pain.
Gave up doing them 15 years ago because of the built in issues.
Best of luck!Last edited by spimps; 04-06-2011 at 05:33 AM.
“Life is like riding a bicycle. To keep your balance you must keep moving” Einstein
