    Feb 2008
    India
    43
    28
    Vacuumisation again..
    Hi Friends,
    We have a big system whose refrigerant(R407C) holding capacity is 60Kg.What do you think what capacity pump is good to get vacuum upto 300microns in 10hour?
    manchester
    5,639
    Re: Vacuumisation again..
    the biggest u can buy.use a 4 way manifold with an 3/8 gaugeline on the vac pump,unscrew the core depressers in the 2 1/4 lines and connect to the rotor lock vaves,-schreader cores restrict the lines,stop the water flow through the evaporator,energise the crankcase heaters and a warm ambient is better.also triple vac using nitrogen to remove moisture.have u changed the liq line drier.
    Croatia
    68
    2,263
    Hi, praveen
    Quote Originally Posted by praveen View Post
    Hi Friends,
    please, search RE forums for vacuum pumps, vacuum etc ... you will find a lot of info ... links .... etc...
    hope you will find what you need
    Best regards, Josip
    Aug 2009
    New Zealand
    2,554
    I think one about "so'' big would do the job nicely, luvly jubly
    Mar 2011
    Australia
    43
    67
    14
    Reciever volume means little. What is the cooling capacity is this a/c or freezer is it a new install you want to get down in 10 hours. If there has been refrigerant or moisture in system its very hard to advise.
    Croatia
    68
    2,263
    hi, mad fridgie
    are you sure that "so" big would be big enough
    Best regards, Josip
    Aug 2009
    New Zealand
    2,554
    hi, mad fridgie
    Best regards, Josip
    Hi Josip,
    with all the info supplied, and use of many complex calculations, plus 30+years experience, I am pretty sure that "SO" big would be the right size, but I am always willing to except when I am wrong, when I am wrong.
    I did think "near enough" would of done, but in 10hrs I had to evaluate again, and a "great big grunter", I thought was just a waste money.
    cheers
    Mad
    Jun 2009
    Lusk , Dublin
    1,115
    Time is irrelevant it will take as long as it takes.Depending on the reason it needs to be vacced in the first place.But that said "SO" big sounds about right.
    Stu
