Thread: City & Guilds 6127
28-05-2011, 07:51 AM #1
City & Guilds 6127
hey guys,
Anyone completed the technical certificate level 3? Did you find it beneficial? if im going to do it ill have to justify it to my employer and would appreciate any feedback.
Thanks in advance.
28-05-2011, 01:22 PM #2
Re: City & Guilds 6127
I did it in 2009 as part of my level 3.
I thought City and Guilds were on about getting rid of it and replacing it with something else?
I'm sure i read that somewhere.The difference between genius and stupidity is that genius has its limits.
Marc
28-05-2011, 08:01 PM #3
They can't take knowledge away from you.
If you are given the chance jump at it. Any training is always benificial.
As far as the industry is concerned a level three is the only qualification
that alows you to work unsupervised. With a level two you are deemed
still to be in training and need supervision.
In the real world people work with no qualifications and are good but you
can't beat being educated and then tie that to experience and you will
always be in work.
All the best
coolrunnings.
Yes it is changing, but only the format and the delivery. The qualification will remain the same.
coolrunnings
28-05-2011, 08:13 PM #4
i did it years ago-heat loss through walls,k valus,u values vapour barriers in coldroom walls,bla bla bla,if your boss is paying then go for it,if u work on splits,vrv's then i wouldnt bother.
29-05-2011, 10:55 AM #5
Thanks guys, i work on most commercial stuff both refrigeration and air conditioning, i started in refrigeration late on after getting a degree in college in IT, doing the level 2 was my first formal learning, found it very beneficial as not only did i learn a lot i also found out just how much i still needed to learn. Ive found doing mainly service/breakdown work that you get stuck in a rut , you can usually fix 80 to 90% of problems but then something comes along and you feel like you havent a clue. You become a parts changer, fans, TXVs, solenoids, MCBs , relays. The hard times that are in it, i think you need to differentiate yourself from the rest. Knowledge is power.
