Results 1 to 2 of 2
    Sep 2005
    India
    49
    30
    Air Source Heat Pump
    How does the wet bulb temp affects the condnsing temp?
    Anup
    Aug 2001
    1,046
    Re: Air Source Heat Pump
    At normal temperatures wet bulb is usually ignored for design condensing conditions indoor and out in small / medium domestic commercial heat pump / refrigeration systems.
    ________
    buy silversurfer vaporizer
  1. dual source heat pump
    Last Post: 12-08-2010, 02:24 AM
  2. frostles heat pump
  3. Replies: 3
    Last Post: 06-11-2006, 05:04 AM
  4. Evaporator Design-Air Source Heat Pump for water heating
    By anup in forum Technical Discussions
    Last Post: 20-03-2006, 02:26 PM
  5. water source heat pump
    Last Post: 29-03-2005, 09:09 PM
