    Sep 2005
    India
    49
    30
    Question Calculation of "U" in Evaporator design
    In Air Source Heat Pump, while designing the evaporator, how to calculate "U"?
    Whether high ambient temp (incidently which is used for refrigerant evaporation and India it could go up to 48 deg. C) affects "U"?
    Thanks in advance for your valuable advice.
    Anup
    Dec 2004
    Weihai,China
    800
    Re: Calculation of "U" in Evaporator design
    contact evaporator manufacturer,they can provide the data for u. or get the software for selection. The simple way is to design on basic data(U is around 30~50w/m2.k which is related to your manufacturing tech or materail etc)but you need to do some test and get your own data. If you want more help,pls list your design reqiurement. perhaps we can do some help.
    rgds
    LC
    Oct 2005
    IRAN
    878
    As you may know U factor in the heat exchangers is the most difficult parameter to evaluate. If one of the design parameter is changed then U will be changed.
    There are so many equations developed to calulate U factor. Each one is good for a range of applications.
    In real life these equations are modified according to the test results and they are used in computer softwares. The reliable and accurate ones are very very expensive?!!!
    Try (If you can) HTFS software ACOL. You must be a member in order to use this software and the membership fee is too much. But in my opinion it is hte most reliable and accurate one. The company is called Hyprotech.
    Cheers.
    Even Einstein Asked Questions
    Dec 2004
    82
    14
    Hola ! ANUP
    Maybe this will help.
    http://www.hvacindia.org.in/journals...article01.html
    Victorman
    Dec 2004
    Weihai,China
    800
    Hi Victorman
    It's a real good site. i‘ve never checked India's web.
    hope more good links- thx
    rgds
    LC
  1. coldroom calculation freeware
    By coldcraft in forum Tools and Calculators
    Last Post: 17-01-2009, 02:31 PM
  2. Heat Load calculation for residential jobs
    By Herschmidt in forum Air Conditioning
    Last Post: 12-05-2008, 11:50 PM
  3. calculation errors
    By Servicefrigo in forum Tools and Calculators
    Last Post: 11-02-2005, 01:53 PM
  4. Load Calculation / Comaprison
    By herefishy in forum Technical Speculations
    Last Post: 04-03-2002, 09:21 PM
