    May 2011
    35
    Building walk-in chiller
    Hi Everyone,
    I've got a monoblock chiller unit and I'd like to build a walk-in chiller for storing food, mainly fish products.
    The space is a bit tricky, its located in the basement and the ceiling is pretty low.
    What I was thinking about to build one of those walk-ins made of PU panels with camlock. The question is where can I buy those in London? Probably I will need special sizes because of the low ceiling, also a door to fit.
    Unfortunately I don't really know anything about how its made, are those panels available in custom sizes? Do I have to make a sketch of it and then they manufacture it?
    Any ideas, suggestions, recommendations about where should I start, which company is manufacturing these panels..etc. I have googled it but found only installers or wholesales. I would like to build it by my own.
    Thanks in advance
    Nov 2008
    scotland
    69
    232
    10
    Re: Building walk-in chiller
    try these guys www.scandia-coldrooms.co.uk
    DM
    May 2011
    35
    Thanks, I will ask them
    Sep 2003
    ISRAEL
    66
    4,153
    38
    If you are going to build it in a cellar, bear in mind that you have to cool the condenser with outside air or your cellar will turn into a sauna.
    May 2011
    35
    Thanks, we have big ventilation pipes with fans sucking the air out. I will just have to cut it shorter to make sure it will be exactly above the unit.
    Oct 2003
    56
    5,519
    28
    There must be a short circuit in the internet-cabkle under the sea or the cable is to long seen the transmission time between Israel and the UK
Tags for this Thread
