    May 2008
    malaysia
    34
    82
    11
    compressor for coldroom
    halo, everybody, another question about which type for bitzer compressor suitable for my coldroom and the total cooling capacity calculation...thanks
    sizing - length 40ft
    - wide 25ft
    - high 20ft
    temp 0 ~ -5 degree c
    Jan 2006
    Croatia
    63
    2,136
    Re: compressor for coldroom
    Hi, ah fai
    Quote Originally Posted by ah fai View Post
    - wide 25ft
    - high 20ft
    What kind of goods and how much you want to keep within your cold room,
    or you plan to keep it empty?
    Best regards, Josip
    May 2008
    malaysia
    34
    82
    11
    around 20ton of fruit & vegetable
    lebanon
    130
    11
    hi
    you need 48 kw compressor 6j-22.2y-40p hope it help
    Oct 2003
    56
    5,519
    28
    If you want cooling capacities, then you have to give us all the info to calculate it. It will vary from 5 till 100 kW and all answers will be correct.
    Jun 2005
    Malaysia
    26
    hi,
    Heat load calculation, need lots INPUT, as it will loading your compressor.
    without this Input you are lost, As Peter_1 said...5 to 100KW...hahahah
    don't forget the product SH (Specific Heat) or (latern heat) is also playing a big rules.
    I trust my software.
    w.l.ong
    Apr 2011
    India
    30
    94
    8
    As others said , you should give us the all details of your cold room like u said 20 tones of fruits and vegetables.Please give us other details like lighting system, on which floor it is , roof is covered or not ; everything which are the source of heat generation should be considered.
