Results 1 to 19 of 19
21-05-2011, 03:50 PM #1
Mitsubishi Electric PQRY-P600YSHM, 1500 ERROR CODE
I have 3 different PQRY-P600YSHM systems at the same building which of each has 1500 error code.
I'm sabsolutely sure that each system has its correct amount of additional refgirerant.
Each system has 2 BC, MAIN is CMB-1010GA1 and SUB is CMB-108GB1.
M-Net addresses are correct also...
I need any kind of help here.
Thanks in advance.
21-05-2011, 05:25 PM #2
Re: Mitsubishi Electric PQRY-P600YSHM, 1500 ERROR CODE
Hi Again,
Some additional info for this thread.
After changing the modes of indoor units which are connected to SUB BC, all solenoids (a,b,c) on this BC remains open and they are never closed again. So, the system pressures drops, performance drops and then 1500 error code occurs.
I never noticed this problem on the MAIN BC.
Best Regards.
21-05-2011, 05:44 PM #3
possible overcharge?
21-05-2011, 05:50 PM #4
can not be overcharge because i checked the calculation for several times.
Thanks for your help.
21-05-2011, 06:04 PM #5
valve shut on condenser?
21-05-2011, 06:23 PM #6
Valve shut risk seems not possible, 3 different outdoor units with same capacity has the same error code.
Please kindly find the attached MN Tool record and check SUB BC solenoids' ON/OFF situations.
21-05-2011, 07:17 PM #7
Here's another record for PQRY-P600YSHM.
Please take a look on both MAIN BC and SUB BC electronic board software versions, VER.1.00.
Also all solenoids of SUB BC "a,b,c are ON".
This is quite weird.
21-05-2011, 07:18 PM #8
1500 Overcharged
refrigerant
abnormality
1. If the discharge SH 10K is
detected during operation (at
first detection), the heat
source unit stops at once.
The 3 minutes restart
prevention mode is entered.
After three minutes, the heat
source unit starts up again.
2. If the discharge SH 10K is
detected again within 30
minutes after the heat source
unit stops (second detection),
an abnormal stop is applied,
and “1500” is displayed.
3. If discharge SH 10K is
detected more than 30
unit stops, the state is the
same as the first detection
and the same operation as 1.
above takes place.
4. The abnormal stop delay
period is in effect for 30
unit stops. The abnormal stop
delay period LED turns ON
during this time.
21-05-2011, 07:21 PM #9
Hi Install Monkey,
Thank you so much for your kind effort. If you have the opportunity to check MN Records, please do. You will see the strange points such as version of PCB and solenoids of SUB BC.
21-05-2011, 07:44 PM #10
cannot open files as they are password protected!
21-05-2011, 07:48 PM #11
21-05-2011, 07:56 PM #12
have u powered down the system and restarted to allow lev's to realign?
21-05-2011, 09:00 PM #13
22-05-2011, 01:07 PM #14
I think your on the right track with regards the SUB BC box. A & C solenoid energised for cooling, B solenoid energised for heating but the SUB BC is indicating all ON, which would say to me the software/PCB is incorrect. Have you spoken to Mitsubishi about this issue?
22-05-2011, 01:16 PM #15
22-05-2011, 01:35 PM #16
26-05-2011, 04:23 AM #17
BC version latest is 1.02 I beleived.
His version is still 1.0 please call Mitsubishi Turkey for this issue.
26-05-2011, 01:30 PM #18
27-05-2011, 07:29 AM #19
Not at all, just put my two cents in your version 1.0, oh yeah that's version 1.02.
