Thread: spell check
29-09-2005, 07:37 PM #1
spell check
can a spell check be added to this board??
I notice several others who have this function so it's not as if this is impossible...
cheers
richard
29-09-2005, 11:27 PM #2
Re: spell check
If you add a Google toolbar you get a spellcheck with that... mind you, you may not want a Google toolbar, so I'll climb back down into my hole again, byeeee
30-09-2005, 04:16 AM #3
Re: spell check
Hi Richard.
There is one!!!
When you reply, look at the top right corner, you will see the letters ABC, and a V under them.
That is the spell check.
But its not automatic,
Chemi
30-09-2005, 09:48 AM #4
Re: spell check
The easiest way is to write your comments in your normal WP programme, MS Word or whatever, then paste it in.
The spell check is automatic, set up to your preferences and is easier than the basic one supplied with the forum.
________
KTM 250EXCLast edited by Argus; 07-02-2011 at 08:37 AM.
How do you check a thermistor?
By Abe in forum ElectricalReplies: 6Last Post: 13-09-2011, 10:12 AM -
Air conditioning maintenance procedure
By Andy T in forum Air ConditioningReplies: 12Last Post: 27-05-2006, 06:57 PM -
Double check needed
By Latte in forum Trouble ShootingReplies: 14Last Post: 11-08-2004, 12:46 PM -
Compressor Check for locked rotor voltage
By shogun7 in forum Trouble ShootingReplies: 0Last Post: 04-04-2004, 12:44 AM -
Leak check dye
By Rango in forum Tools and CalculatorsReplies: 4Last Post: 05-02-2004, 11:11 PM
