    aziabdul's Avatar
    aziabdul Guest
    Oil Free Compressor
    Thanks for reading this post.
    I am doing small report on oil free compressor. Wanted to know the applications areas where oil free air is required for following segment:
    1. Chemical
    2. Pulp & Paper
    3. Construction equipment
    4. Glass Processing
    Also, how are maintenance activities different for screw and turbo oil free compressor.
    Thanks in advance.
    Regards,
    Abu
    Sep 2008
    427
    Re: Oil Free Compressor
    Hi Aziabdul,
    You`ve missed one out: food processing.
    Maintenance wise there`s not much difference from lubricated compressors, air filters, inlet regulator seals, motor bearing greasing need changing on both types but on oil free there`s balance piston diaphragms to change and gear box breathers to check. The gearbox oil is usually changed at 8000hr
    Lubricated compressors require the oil seperator elements changing at 8000hr or if the DP reaches .5 bar and usually the oil changing at 2000 hrs or 8000hr if it`s synthetic (subject to analysis).
    One major difference between the two is the price of overhauled air ends, the oil free are horrendous. so much so that many industries prefer to use lubricated compressors with food grade oil where possible.
    Auckland
    74
    3,357
    37
    Another possibility in refrigeration is the Danfoss USA oil less twin turbo centrif.., water chillers
    aziabdul's Avatar
    aziabdul Guest
    Thanks for your inputs.
    Is there any kind of link from where i could get more information regarding the maintenance activities.
    Also, for the segments that I mentioned there are few application that require oil free air as any contamination in air could hamper the process. I want to understand those application areas.
    Apr 2009
    israel
    778
    Hi :
    google danfoss turbocor, i think you will find this interesting.
    enjoy:
    http://www.turbocor.com/
    THE DEFINITION OF A SMART PERSON IS ONE WHOM LEARNS FROM HIS MISTAKES!!!
