Results 1 to 1 of 1
Thread: Case shelf lights
14-05-2011, 02:58 AM #1
Case shelf lights
Question, How are the connections made for shelf lighting in multideck cases in other parts of the world?
On cases here it's a plug with an oring . The problem is when the case gets down to temp it's impossible to push it in without using a wooden rod and a hammer. I'm thinking a twist lock would be better. Just curious how that connection is made on non american made cases? Pictures would be great. I understand your dealing with moisture and nsf approval etc.
Alot of the cases here are using low voltage led lights now.
Thanks.
