Thread: Glycol chiller
29-09-2005, 10:53 AM #1
Glycol chiller
Hi all,
Can anyone advise how to determine the percentage of glycol to water ratio in order to get certain temperature
Secondly, based on the calculated capacity, how do we determine wat is the evaporating temperature to select compressor
Thanks for all your help.
30-09-2005, 04:48 AM #2
Re: Glycol chiller
You can refer to refrigeration handbook to determne the glycol ratio related to the operation temp. The evaporative temp and capacity is decided by your application requirement(e.g food storeage\air condition\industrial etc). Maybe I can offer more if you more specific.
rgds
LC
30-09-2005, 05:39 AM #3
Re: Glycol chiller
Dear LC,
Cooling cap of 232 kW, Propylene Glycol
Ent/ leaving temp : -5 / -10 deg C
(i think PG with 39% of which having freezing point of -20 should be enough)
Plate heat exchanger with 5 kTD across glycol and R22 circuit.
Perhaps I can use -20 deg C as SST to select a multi-compressor set?
On Glycol side, i'm planning to have one expansion tank and one mixing tank. To use expansion tank is because the system is not of 24 x 7 days duty. They off it during weekend.
Please comment on this..
Rgds,
Kevin
Dunham Bush Chiller Alarm
By Regulator in forum Air ConditioningReplies: 11Last Post: 08-12-2010, 01:42 AM -
DIY aquarium chiller
By BarraCuda in forum Technical DiscussionsReplies: 18Last Post: 06-10-2010, 11:02 PM -
York Screw Chiller How low will it go?????
By bruceboldy in forum Industrial CompressorsReplies: 11Last Post: 10-08-2007, 10:29 PM -
Milk getting into glycol on chill press
By balerjoe in forum Trouble ShootingReplies: 16Last Post: 06-09-2005, 09:41 PM -
which glycol to use ?
By dchatta in forum RefrigerantsReplies: 4Last Post: 12-07-2004, 09:26 AM
