Thread: R290a & R600a
    Sep 2009
    Gauteng
    R290a & R600a
    Hi Guys,
    Just a quick question, can you replace R290a refrigerant with R600a refrigerant?
    Oct 2006
    1,843
    21
    Re: R290a & R600a
    Not easily...
    They are different refrigerants and work slightly differently.
    Its like saying can I swap 134a with 407c or some other similar refrigerant.
    taz
    Mar 2011
    Singapore
    212
    Re: R290a & R600a
    Even though both are HC refrigerants, but I don't think is easy. Don't take the risks.
    Sep 2009
    Gauteng
    Re: R290a & R600a
    Thanks for the advice!
    May 2011
    8
    Re: R290a & R600a
    You can check with the compressor manufacturer and do some preliminary studies based on the pressure temperature charts. I have an application for a food freezer running r507a (*****) and we are planning to swap for r717 (ammonia). If you do your homework and design it may work.
    May 2004
    southern england
    69
    86
    21
    Re: R290a & R600a
    R290a is an IsoPropane, R600a is IsoButane
    it's only a fridge, fix it. ;)
