Thread: Testing chamber
    Dec 2010
    Toronto, Canada
    1,454
    Testing chamber
    I don't know if this is the right heading for this subject but here goes...Does anyone have a good idea how I should build a test chamber for ASHPS? It will have to go down to -25C or maybe lower (with a 25C ambient) and be able to keep up with a 30kw system trying to remove what little heat there is left in the air at that temp. Next door to it will be a controlled room which could be set to typical household ambient conditions, 5-22C for example. It obviously won't be running 24/7 but I would like it to be as efficient as possible.
    Any thoughts, which refrigerants or comps to use.
    Aug 2009
    New Zealand
    2,554
    26
    Re: Testing chamber
    No need for refrigeration, your ASAP will cool the chamber and keep it cold, you will need to introduce some energy and humidity for correct testing
    Dec 2010
    Toronto, Canada
    1,454
    Re: Testing chamber
    I will have to have a load that always needs satisfying, a 500L tank for example which will need a small chiller and that part is easy but if I wanted to simulate a very cold start on the evap side rather than a gradual pull down.......... Duh...OK, a very small room will get very cold quickly. Thanks for the reality check MF. Must be I didn't have enough beer for clear thought.
