Results 1 to 18 of 18
Thread: Ammonia system
    Oct 2006
    Romania
    52
    13
    Ammonia system
    Dear friends,
    I have to repair an facility that serves the freezing tunnels and storage of frozen products.
    In facts the plant is DX ammonia system which doesn't work properly.
    So, the frozen product ( -20C room temperature) is works properly when the freezing tunnels is off. The tunnels do not reach freezing temperature, even when frozen deposits are stopped.
    So I am thinking about to keep the circuit (DX) for the frozen product store and to mount an separatelly liquid separator pumps and ammonia pumped air coolers for freezing tunnels.
    In fact to use the same compressors and evaporating condenser. But after the liquid receiver to split in one DX circuit and another one for ammonia pumped. For return circuit to join again the two circuits before the suction of compressors.
    Do you think is it possible something like this?
    Will working?
    Thanks for your help.
    Sep 2008
    Canada
    811
    Re: Ammonia system
    Are you sure that you have DX coils? Usually, people use TEVs and DX coils for high temp. evaporators.
    To solve the problem, you should find out the reason of this problem. If evaporators, suction line, compressor capacity are under sized, liquid pump will not help.
    Dec 2008
    Portugal
    48
    1,020
    Re: Ammonia system
    Herman,
    What's the problem of the plant?
    Jan 2006
    Croatia
    68
    2,263
    31
    Re: Ammonia system
    Hi, herman
    Quote Originally Posted by herman View Post
    Dear friends,
    Will working?
    First I have only a few questions, because something is not clear to me...
    A1. How old is your plant? Probably very old..
    A2. The problem you described are from the day one or jump out by the time? Probably from day one ....
    B. What you can tell us about (please, give us some figures):
    1.Capacity of evaporator in cold room/s-freezing storage/s at -20*C
    2.Capacity of freezing tunnels
    3.Capacity of compressor/s at -40*C/35*C (type and size of electrical motor)
    This will put some more light on your plant and hopefully give us chance how to help you.
    Best regards, Josip
    Oct 2006
    Romania
    52
    13
    Re: Ammonia system
    Quote Originally Posted by Josip View Post
    Hi, herman
    Best regards, Josip
    Hallo,
    here are the answers to your questions:
    A1. It's a new one plant; 1 year old
    A2. The problems apperared from the first day
    B 1. 60 kW storing rooms ( -20C)
    B2. 65 kW freezing tunnels ( -30C)
    B3. I don't know the cooling capacity. The compressors 2 pcs, Mycom 200 VLD H; electric motor 200 kW ( Leroy Sommer PLS 315)
    Thank you for your help!
    Oct 2006
    Romania
    52
    13
    Re: Ammonia system
    Quote Originally Posted by Sandro Baptista View Post
    Herman,
    Here is the problems:
    Dec 2008
    Portugal
    48
    1,020
    Re: Ammonia system
    What you mean with frozen deposits are stopped? When the tunnel is empty what is the lower temperature you can reach?
    What's the suction pressure of the comps and its set point. What's happening to the suction pressure when all is working. The cold store share with the tunnels the same compressors, as far I understood, right?
    Auckland
    74
    3,357
    37
    Re: Ammonia system
    What are the operating pressures at the compressor? Have the commissioning start up socks been removed from compressor suction strainer?
    The mycom 200VLD-H should eat the load, at -35/+35 'C = 250 Kw duty.
    Sounds like system loses in pipework maybe something to start with. Liquid overfeed coils are purpose designed, so converstion from DX to flooded is not straight forward.
    Jan 2008
    West Coast British Columbia
    106
    Re: Ammonia system
    SINGLE STAGE SCREW COMPRESSOR : 14.0 MYCOMW 14.0ep
    DATE : 05-17-2011
    MODEL : N200VL*-H
    REFRIGERANT : AMMONIA
    RECOMMENDED PORT : H
    BOOSTER : False
    COMPRESSION RATIO : [-] 14.5
    CAPACITY : [kW] 304.4
    CAPACITY : [TR] 86.6
    ABSORBED POWER : [kW] 181.3
    DRIVE SHAFT SPEED : [rpm] 3550
    COMPRESSOR SPEED : [rpm] 3550
    INDICATOR POSITION : [%] 100
    CONDENSING TEMP. : [degC] 35.0
    EVAPORATIVE TEMP. : [degC] -35.0
    SUCTION SUPERHEAT : [degC] 3.00
    LIQUID SUBCOOLING : [degC] 5.00
    SUCTION TEMP. : [degC] -32.0
    OIL SUPPLY TEMP. : [degC] 50.0
    SUCTION PRESS. : [MPaA] 0.093
    DISCHARGE PRESS. : [MPaA] 1.35
    OIL SUPPLY PRESS. : [MPaA] 1.54
    SUCTION PRES. DROP : [MPaA] 0.000
    DISCHARGE PRES. DROP : [MPaA] 0.000
    SWEPT VOLUME : [m3/h] 1460
    LOAD(VOL. FLOW RATE) : [%] 100
    DISCHARGE TEMP. : [degC] 85.5
    REFRIG. FLOW RATE SUC. : [m3/h] 1260
    REFRIG. FLOW RATE DIS. : [m3/h] 127
    REFRIG. FLOW RATE SUC. : [kg/h] 1023
    REFRIG. FLOW RATE DIS. : [kg/h] 1023
    INJECT. OIL FLOW RATE : [L/min] 58.4
    LUB. OIL FLOW RATE : [L/min] 54.6
    F.SIDE OIL FLOW RATE : [L/min] 9.47
    *TOTAL* OIL FLOW RATE : [L/min] 122
    OIL HEAT REJECTION : [kW] 122.7
    OIL SPEC HT : [J/kgK] 1930
    OIL DENSITY : [kg/m3] 880
    COP : [-] 1.68
    --- SUPER HEAT is NOT counted in refrigeration capacity ---
    --- WITH WATER COOLED OIL COOLER ---
    --- Refrigeration oil is not soluble with refrigerant (mineral oil) ---
    --- When choosing the motor set a safety factor of more than 10% for the brake power ---
    plenty of kW's for cooling.
    If it was the suction sock the system would be going down on low suction but the liquid would be hotter than suction pressure.
    Refrigeration is not just cool, it is my life.
    Nov 2004
    China
    176
    Re: Ammonia system
    Low temperature Dx ammonia systems can be a nightmare. Sounds like some commercial ***** engineer was let loose here. Get rid of all of the expansion valves and install a proper pumped ammonia system. Or bring a bed to the plant 'cause that's where you'll be living.
    Jan 2006
    Croatia
    68
    2,263
    31
    Re: Ammonia system
    Hi, herman
    Hallo,
    Seems you have enough cooling capacity within compressors - I prefer tunnel evaporating temperature to be -45*C or max -40*C freezing must be very fast to protect the goods (-35*C ET we use for ice cream cold room to keep the room at -26*C - safety margin for handling), but even at evaporating temperature of -45*C your compressor will give more capacity then you actually need....
    Hope that you have suction pipe size min of DN 150mm/6" i.e. common suction pipe for parallel work of cold storage room and tunnel ...
    One more question ... can you reach freezing temperature when your tunnel is empty or 25% i.e. 50% full?
    Something must be wrong with DX system for freezing tunnel ... I agree with charlie n to revamp that one to pump system ....
    Best regards, Josip
    Auckland
    74
    3,357
    37
    Re: Ammonia system
    Hi Iceman_ 4000.
    I quoted duty at 50 Hz. Do not know what power supply is in Romania
    Dec 2008
    Portugal
    48
    1,020
    Re: Ammonia system
    Hi Iceman_ 4000.
    If you see the speed motor he considered 3.550 rpm (60 Hz)
    Jan 2006
    Croatia
    68
    2,263
    31
    Re: Ammonia system
    Hi, IceMan_4000
    Quote Originally Posted by IceMan_4000 View Post
    DATE : 05-17-2011
    MODEL : N200VL*-H
    BOOSTER : False
    In Romania they use 50 Hz i.e. capacity is 20% lower, but still enough around 240kW....
    Best regards, Josip
    Jan 2008
    106
    Re: Ammonia system
    Ops sorry guys totally missed the 50hz
    Thanks for the correction Josip
    SINGLE STAGE SCREW COMPRESSOR : 2011 MYCOMW 2011ep
    DATE : 05-18-2011
    MODEL : N200VL*-H
    BOOSTER : False
    CAPACITY : [kW] 243.5
    CAPACITY : [TR] 69.2
    ABSORBED POWER : [kW] 159.6
    DRIVE SHAFT SPEED : [rpm] 2950
    COMPRESSOR SPEED : [rpm] 2950
    SUCTION SUPERHEAT : [degC] 0.00
    SUCTION TEMP. : [degC] -35.0
    OIL SUPPLY PRESS. : [MPaA] 1.55
    SWEPT VOLUME : [m3/h] 1210
    DISCHARGE TEMP. : [degC] 82.4
    REFRIG. FLOW RATE SUC. : [m3/h] 994
    REFRIG. FLOW RATE DIS. : [m3/h] 96.4
    REFRIG. FLOW RATE SUC. : [kg/h] 816.8
    REFRIG. FLOW RATE DIS. : [kg/h] 816.8
    F.SIDE OIL FLOW RATE : [L/min] 9.48
    *TOTAL* OIL FLOW RATE : [L/min] 123
    OIL HEAT REJECTION : [kW] 112.3
    COP : [-] 1.53
    Jan 2008
    106
    Re: Ammonia system
    -45 capacity
    DATE : 05-18-2011
    MODEL : N200VL*-H
    BOOSTER : False
    COMPRESSION RATIO : [-] 24.8
    CAPACITY : [kW] 136.5
    CAPACITY : [TR] 38.8
    ABSORBED POWER : [kW] 140.4
    EVAPORATIVE TEMP. : [degC] -45.0
    SUCTION TEMP. : [degC] -45.0
    SUCTION PRESS. : [MPaA] 0.054
    DISCHARGE TEMP. : [degC] 81.6
    REFRIG. FLOW RATE SUC. : [m3/h] 933
    REFRIG. FLOW RATE DIS. : [m3/h] 54.7
    REFRIG. FLOW RATE SUC. : [kg/h] 464.6
    REFRIG. FLOW RATE DIS. : [kg/h] 464.6
    INJECT. OIL FLOW RATE : [L/min] 60.2
    LUB. OIL FLOW RATE : [L/min] 55.1
    F.SIDE OIL FLOW RATE : [L/min] 9.58
    *TOTAL* OIL FLOW RATE : [L/min] 125
    OIL HEAT REJECTION : [kW] 111.7
    COP : [-] 0.972
    Mar 2004
    Peckham,London
    38
    Re: Ammonia system
    looks like compressor has enough capacity!
    DX??
    you should go flooded evaps, pumped recirculation with low pressure receiver. Pipe work length will have an effect on DX refrig. pumped recirc with low pressure receiver will over come this.
    fridge
    Mar 2005
    638
    Re: Ammonia system
    DX is basically a NO-NO for anything below about 10 degF for ammonia. There is too may problems associated with proper circuiting and and feeding the coil circuits. To be quiet blunt, anyone that would install a DX ammonia freezer like you described has to be a total idiot.
    You can probably redo the feed headers on the coils and add a gravity or liquid recirculation system and make the coils work.
Tags for this Thread
