Results 1 to 8 of 8
Thread: slush machine
    Nov 2008
    scotland
    74
    232
    slush machine
    Anyone worked on these slush machines I took one on as a favour for my pub landlord he gives them out free to kids or adults as a mixer for vodka never tried it so I cant comment, anyway R404a is about all I can tell you, do they need syrup to work ? I tried just water and ice forms on the cylinder and starts scraping like mad,It's going ok I am going to put gauges on and I wondered what I should expect, same as ice machines ? anyone
    DM
    Sep 2003
    ISRAEL
    72
    4,248
    Re: slush machine
    R-404 and syrup is delicious Most kids can't resist it
    Just joking, couldn't resist.
    Apr 2008
    canada
    75
    94
    Re: slush machine
    B”H
    Devlin,
    Any slush machine can operate ONLY with the mixture of water and freezing depressant substance like sugar, syrup, fruit juice, salt, glycol and so on. Depending of the design of the scraping mechanism the concentration should be from 3% and up.
    Jul 2010
    NTH.QLD Australia
    1,730
    32
    Re: slush machine
    Been a while since i've worked on one. Minus 2c is the pour temperature however the owner should have syrup ratio if he's been using machine. Vodka in the mix?? What a sheltered life i've had...
    Feb 2008
    adelaide sth.oz
    1,015
    Re: slush machine
    if its working why fit gauges?
    get rid of the vodka and hit it with tequila.
    make sure the reduction box swings freely,swig freely yourself.
    Nov 2008
    scotland
    74
    232
    Re: slush machine
    Hi all the gauges thing was curiosity, , and the reduction box well its missing a spring that hols it against the micro switch which does ? any way when I get it going I am going to have a slush party sounds like a politcal convention eh? !!
    Nov 2006
    708
    23
    Re: slush machine
    The microswitch operates the solenoid valve which feeds the evapator drum with refigerant
    Jul 2010
    NTH.QLD Australia
    1,730
    32
    Re: slush machine
    Some machines have a 70 second delay, that is, when the resistance of the mix is greater than the spring tension holding the motor and gearbox, then motor twists and forces microswitch to close, BUT it has to hold microswitch in for the 70 seconds without letting up to shut off compressor. In these models, this ensures consistant mix and eliminates compressor short cycle... Spring tension is critical for machine to run correct. Too much tension and mix solidifies and damage can happen if shear pins don't let go first.. Mike.
