    ibnibrahim2000's Avatar
    ibnibrahim2000 Guest
    Question Suitable cooling system for Domestic uses
    Hai
    We are in Gulf region. In the summer temperature will rise upto 50degress there by the water also will be too hot. So please suggest a feasible cooling system to have the cool water (18 to 22 Degrees). V have two ground Tanks (each of capacity 4000 USG each) and 6 over head tanks (each of capacity 600 USG). We have to use the water for drinking as well as other uses (washing, bathing etc).
    Auckland
    68
    3,362
    32
    Re: Suitable cooling system for Domestic uses
    +50 degrees, is HOT.
    For drinking water try finding a domestic inline water chiller. Does it get cold at night like most desert places. Use a pump and coil with fans to drop temp of water in tanks, plus paint them with white reflective paint to slow heat gain. Even insulate them.
    Oct 2008
    mallorca, spain,
    69
    771
    13
    hi , bottled water = in fridge, perfect <you never know when a camel has been dribbling in the water source<
    sedgy
