Thread: panel mount clocks
28-04-2011, 07:38 PM #1
panel mount clocks
Any one know a suppier that stocks gauges I can panel mount
Dev
28-04-2011, 07:58 PM #2
Re: panel mount clocks
kooltech have just got me some panel mounted gauges-normal mainfold gauge heads and a lipped ring to go round the 80mm gauge to mount but beware u also need 2 1/8mpte-1/4 male connectors to couple up to a flared connection.also the connections are at the bottom.
28-04-2011, 08:10 PM #3
I think I will adapt and improvise cheers
Dev
28-04-2011, 08:38 PM #4
28-04-2011, 11:19 PM #5
Bear in mind that most gauges have two screws in the back holding the cover to the gauge internals.
If you cut your panel hole to slightly under size of the gauge you could make up a bracket to fit those two screws that would clip onto the back of the panel door sheet.Brian - Newton Abbot, Devon, UK
