Results 1 to 10 of 10
    Nov 2008
    scotland
    74
    232
    recovery machine ?
    What do they mean by an oiless compressor,surely a contradiction in terms,if it has a recip piston it needs lubrication,any one ?
    Devlin
    3,856
    Re: recovery machine ?
    All the small ones are oilless now! thats why they are so noisey,
    http://advancedengineering.co.uk/uk-...ct.asp?pid=241
    Like a lot of hobby air compressors now, i think they use teflon or some such in the cylinder to reduce friction.
    Jon
    Sep 2003
    ISRAEL
    72
    4,248
    As simple as it says, no oil.
    Jul 2010
    NTH.QLD Australia
    1,730
    32
    There was a problem with some models. Apparently, when first used straight out of the box, one has to recover refrigerant from a recently opperating system, rather than something that had been shut down for some time. I was told it had to do with oil with the refrigerant that lubes the machine parts. Yeh, they are noisy.. Mike.
    Feb 2010
    242
    They use carbon fibre pistons, con rods and rings so don't need
    oil to run. Oil from the system passes through but they are deemed oil free.
    Cool runnings
    Nov 2006
    708
    23
    Carbon filled ptfe is the material most compressors use.
    You only need to spit on carbon to lubricate it
    Nov 2008
    scotland
    74
    232
    So it's a gimmick then you still need to be carefull with oil cross contamination I thought maybe it had a oil removal system, at the price they want for one I would have thought it was platinum ****** plated
    Dev
    Jun 2009
    North East England
    41
    712
    It's no gimmick as long as you use the correct methods there will no cross contamination, I use mine all the time on various gases and not had a problem yet, could be 22 one day or 404 the next
    Sep 2008
    427
    Even big compressors can be oil free, 340hp double acting air compressors use PTFE piston rings and austenetic liners. They cost a fortune to maintane so they`re a disapearing breed now
    Dec 2010
    ZA
    154
    Gast make oil free vacuum pumps. Lovely units, but expensive! I use a set of old carbon vanes as a cup holder, figured that is about all they are usable for after removal, unless I need a big 4H pencil.
