hello all..
I have a small deep freezer and a topmount no-frost fridge..
Fridge compressor died last year, while the deep freezer stopped freezing stuff, so I started using is as a fridge.
I decided to fix them, so I got a guy who replaced the fridge compressor, and recharged gas for both the fridge, and the deep freezer.
After using them, I found that:
-The suction line in both of them (the line from the box to the compressor) started to ice up after a few minutes..
-Cooling in both is not good.. the temperatures of both appliances are between 15-30F.
-The fridge takes ages to power off. I took the thermodisc off and tested it, and it works just fine.
I asked around and someone told me that they are overcharged with gas. so, part of the cooling power is wasted cooling the suction line instead of cooling the evaporator. therefore, frost build up, and cooling not so good.
I wasn't gonna use the deep freezer any time soon, so I thought I'd experiment with it. so, I used the valve (which the guy installed in the compressors) to release some gas.. but the frost on suction line never went away..
Any advice??
