    Snupa's Avatar
    Snupa Guest
    Bolted Flange Chilled Water Joints (UK)
    Can someone direct me where to find some information on the above.
    I would like to know if there is a 'standard' which dictates the minimum number of exposed threads on a bolt of a flanged pipe joint.
    I would also like to know if bolt torques in this application are specified anywhere. Are these generally applied, or is a general degree of 'handtighness' acceptable.
    Thanks.
    11,192
    Re: Bolted Flange Chilled Water Joints (UK)
    Does this help at all?
    http://www.buystainless.co.uk/produc...c/nut-bolt.htm
    I think that the correct torque setting is two loud grunts, one on each spanner.
    Snupa's Avatar
    Snupa Guest
    Thanks, Brian.
    That's a useful table, but doesn't give me what I'm looking for.
    As for the torque, I think you are spot on !
    Anyone else ?
    11,192
    It's fun playing with Google and Wikipedia...
    You are looking at/for EN ISO 4753 but I haven't found a free copy yet.
    There is an engineering forum which has discussed this and one thread (pun) which may answer your question is here..
    http://www.eng-tips.com/viewthread.cfm?qid=57019
    Basically it seems that you should have one thread diameter length through the nut.
    Apr 2008
    Southampton, England
    49
    1,044
    35
    A mate of mine who did an apprenticship at a dockyards remarked to me once that he was taught that there should be 2 threads poking out the end. Funny but I never thought I'd ever have the need to pass that nugget of infomation on.
    As for the tightness I believe there are generic torque settings for certain pitches and materials. Not looked but I suppose the mighty Interweb will have it somewhere. If there is oil/grease on the threads then the final tightness will be tighter than a dry thread. Friction and all that jazz.
    As Brian says though, a Jackson Overtorque should do it.
    Cheers,
    Andy.
    Snupa's Avatar
    Snupa Guest
    Thanks Guys. I'll try and find those standards quoted. In the meantime, I've found that the HVCA (Heating and Ventilation Contractors Association) have a publication on this topic which calls for two threads protruding from through the nut. This is consistent with other answers here.
    Thanks again.
