Results 1 to 2 of 2
Thread: Trane system
16-04-2011, 08:53 AM #1
Trane system
Hi All looking for some advice on a Trane YCD 75 Roof top package unit.
The issue is that the system is struggling to cope with current conditions in a kitchen. I am looking to upgrade the air volume entering the kitchen. Currently out the grills I am receiving 2mls. The system is using a factory fitted 1.2kw motor. The maximum that it can be up graded to is a kW. This is what I was thinking of installing. But has any one done this procedure? And what results have they had? Also what size would I need to upgrade the air intake grill to. Any advice will be appreciated
22-04-2011, 07:25 AM #2
Re: Trane system
not so simple,when raising your air flow you will be probably be lowering your cooling output,evry unit has design limits ,the coil is good only to a designed air flow!you should take some mesurments ,like delta t ,on the coil ,refrigerant pressures ,this will give us a good sense of how ,your current unit is working .
good luckTHE DEFINITION OF A SMART PERSON IS ONE WHOM LEARNS FROM HIS MISTAKES!!!
